Page 29 - MetalForming March 2020
        P. 29
      RushJob? NoProblem.
AMADA’s patented Automatic Tool Changer allows
you to easily switch from production to rush job
in minutes.
With a conventional press brake, switching to a rush job in the middle of production creates costly delays and causes bottlenecks that limit your shop’s overall capacity. AMADA’s HG ATC resolves these issues. The system’s Automatic Tool Changer (ATC) precisely loads even the most complex tooling setups in three minutes or less — eliminating the need for manual tool setup and test bends.
Since rush jobs can be veri昀ed of昀ine with AMADA software,
your operator simply loads the new part program. Then, the
ATC performs error-free tool changes in a matter of minutes, even seconds — allowing your operator to quickly start bending.
The ATC works with the system’s AMNC 3i control to ef昀ciently
reposition tools that are used in common between different bend programs. Consequently, as soon as the rush job is complete, your operator can quickly return to production by selecting the previous part program and tool setup — resuming at the exact bend where they left off. Now that’s smart and ef昀cient bending.
   AMADA AMERICA, INC.
180AmadaCourt • Schaumburg,IL60173 www.amada.com/america 877-262-3287
Imagine performing 3 tool changes in less than 3 minutes. Scan the QR code to see for yourself the ultimate solution for rush jobs and complex tool layouts.
Depending on model, the HG ATC is equipped with 18 or 25 stockers for dies and
15 or 18 stockers for punches.
Stay In Touch With What’s Next.
