Page 47 - MetalForming October 2011
        P. 47
                                                    The Future of Waterjet Technology
KMT Waterjet Systems Booth 2355
KMT Waterjet Systems. Baxter Springs, KS, will introduce the Streamline Pro 100,000-PSI, 7000- bar waterjet pump. In addi- tion to increasing linear cutting speed by more than 100 percent in some appli- cations, the second-gen- eration KMT Streamline Pro Series of ultra-high- pressure pumps cuts non- linear aluminum, steel, tita- nium and stainless steel as much as 75 percent faster than standard waterjet sys-
tems cutting at 60,000 PSI, say company officials.
KMT also will introduce its new economy-line waterjet pump, the NeoLine Series, an entry-level option for low-volume job shops, sign shops, and automotive-parts and prototype
Sustainable success in a global market
 fabrication.
A Pair of Servo Presses—
Straightside and Gap Frame
Aida-America Corp. Booth 3125
Aida-America, Day- ton, OH, will exhibit and demonstrate two servo presses from
www.kmtwaterjet.com
 22nd International Sheet Metal Working Technology Exhibition 23-27 October 2012 • Hanover, Germany
  its extensive range of
metalforming solu-
tions. An NS2-
1600(D) 160-ton
straightside servo
press will be part of
a completely func-
tional line, stamp-
ing parts and pre-
sented at the show
in cooperation with
Formtek/CWP, Dayton
Progress, AG Tool & Die and Anchor
Danly. The press is provided courtesy
of Royal Die & Stamping. The second press on display will be an NC1-1100(D) 110-ton gap-frame servo press, demon- strating the servo press’ unique ability to reduce reverse ton- nage. Both servo presses will allow attendees to evaluate how they can optimize flexibility through an infinite number of freely programmable, application-optimized speed, velocity and dwell profiles. www.aida-america.com
Sheet metal, Tube, Section • Handling • Forming Finished products, Parts, Assemblies • Separation Flexible sheet metal working • Machine elements Tube / Section working • Composites • Joining, Welding Surface treatment • Tools, Dies • Safety at work Controlling, Regulating, Measuring, Inspection
Data capture / processing • Quality control Factory and warehouse equipment Environment protection, Recycling Research and development • CAD/CAM systems
www.euroblech.com
MetalForming/October 2011 45
Mack Brooks Exhibitions Ltd
