Page 55 - MetalForming October 2011
P. 55
STANDARD- BENCH Models
and Growing!
2-35 Ton
Standard Non-Rotation RAM
Two Post Guided Tool Plate
Four Post Guided Tool Plate
Guided Tool Plate
Compact Economy Model
STANDARD FLOOR Models
and Growing!
4-250 Ton
Guided Tool Plate
The Magnum Press line of hydraulic C-Frame gap design presses is one of the most complete in the industry and most series are fully customizable. With a standard hydraulic press variety from 2 to 250 ton and broad reaching custom capabilities to 1500 ton and beyond, Magnum has the hydraulic press for you!
www.magnumpress.com
Fiber Laser Makes its Debut
Mazak Optonics Booth 1148
Mazak Optonics, Elgin, IL, will showcase a wide
range of applications and demonstrate sever-
al new machines, including
the debut of its fiber
laser. Built on the com-
pany’s Optiplex platform,
the laser achieves
extremely high speeds
via an IPG fiber resonator, which
reportedly yields faster cuts through thin
gauge material and significantly reduces operating costs. The company’s new OPTI- PLEX 2D laser-cutting system with flexible two-pallet changer provides high through- put, AO/5 automated setup technologies and rugged construction. During booth demon- strations, show attendees will experience the machine’s new user-friendly PreView II touchscreen control and new 4000-W type 10 resonator. Also on display: the Super- Turbo-X Mark III, with power output boosted to 6000 W; and a new modular materi- al-automation system expandable to serve one to four laser-cutting machines.
Press-Feed System Ready to Roll
Formtek Maine Booth 3123
www.mazakoptonics.com
Formtek Maine will dis-
play and run a complete 12-
by 0.125-in. by 8000-lb.
press-feed system in con-
junction with Aida (booth
3125). The system will uncoil,
straighten and feed 0.060in-
thick by 5.65-in.-wide HSLA 340 material at feed lengths of 5.125 in. into a 160-ton servo press. The press will be stamping coasters, to be given away to show visitors.
Fine-Plasma Cutting
Komatsu America Industries Booth 3150
Komatsu, Rolling Meadows, IL, will introduce the Twister fine-plasma cutting machine, rated for cutting 1⁄4-in. mild steel at 180 in./min., 1-in. plate at 45 in./min., and 5⁄8- in. aluminum at 60 in./min., with remarkable edge finish. The machine’s patented high- speed swirling assist gas pro- vides minimal dross and opti- mum cut quality. Standard features include automatic setting of cutting parameters, gas selection, argon marking, and anti- patter shield. Also standard is a push-pull
zoned exhaust system with sliding scrap drawers.
www.formtekinc.com
MetalForming/October 2011 53
www.komatsupress.com
