Page 29 - MetalForming June 2019
P. 29
Need Video to Support Your Website and Social Media Platforms?
Fabrication
Threaded Holes in Thin Material
Thin material poses challenges should threaded holes be required, with additional hardware and second- ary operations often needed. Thread- form tools employed in a punching machine provide an ideal alternative.
“A thread-form tool, with built-in coining capability, produces an offset emboss with a hole in it, either round or keyhole-shaped,” explains Erler. “A self-tapping screw threads that hole, with the screw head sitting flush with or below the sheet—typically the ideal fit. There’s no need for special hard- ware. Wilson Tool’s thread-form tool features a built-in coining operation to handle thicker material than what the thread size normally would call for. It’s one hit, followed by forming.”
Tapped Holes
Tapping holes within a punching machine eliminates a common sec- ondary operation, and tapping can occur at any location on the sheet. And, tool capabilities enable rollformed tap- ping as opposed to cut threads. Roll- formed tapping yields stronger threads with higher tensile strength, and because the threads are formed, not cut, tools produce no shavings.
“A quick-tap tool, depending on the thread size, locates either in the C or D station,” says Erler. “Users can thread either pierced or extruded holes, with extrusions upformed or downformed. Given perfect conditions, speeds approach 200 taps/min. The fastest manual operations just can’t compare. Also, punching machines can relocate directly over holes when tapping, which means high repeatability and high- quality threads.”
The List Goes On
Beyond what’s described here, fab- ricators can perform other operations in a punching machine that conven- tional wisdom routes to stamping presses, press brakes and standalone secondary operations. A discussion with machine and tool suppliers should provide enlightenment and help you win the efficiency game. MF
Fact: The “Play” button
is the most compelling feature on the web;
72 percent of B2B
buyers and researchers watch videos to support their buying decisions.
Yes,
Let MetalForming magazine help. Now available, in partnership with Toth Media, LLC:
Request a quote today— e-mail bkuvin@pma.org.
MetalForming/June 2019 27
