Page 33 - MetalForming November 2019
P. 33
 sive fastening methods, producing an unbreakable joint even in dis- similar materials.
Extrusion
Function: Produces screw holes, tube holders and locators, and doubles as a connector.
Benefit: When paired with a round hole, the extrusion snaps and locks two parts in place.
Scratch
Function: Designed for sheet stopping and as a weld locator.
Benefit: Scrapes material into
material, leaving no holes or marks on the opposite side.
Bridge
Function: Used for parts that require dividers, ventilation or wire tie-downs.
Benefit: Doubles as an efficient sheet-topping solution.
Cluster
Function: With two to 120-plus tips per punch, makes holes with each stroke of the machine.
Benefits: Less time required for punching and managing sheet stretch. Combats sheet distortion and oil canning that can result from perforation applications. Add a back-bending die to reduce dis- tortion further.
Louver
Function: Creates louvers for airflow or ventilation applications. Benefit: Also can be used to cre- ate stops in less time and for less
money than using jigs or fixtures.
MetalForming/November 2019 31
With two to 120-plus tips per punch, perforating with cluster tools is fast and efficient.
a stop on one side of the
Half Shear
ROBOTIC END-EFFECTORS
We had seconds to connect air, fluid
and power to an assembly platform.
The fully automated ATI Utility Coupler delivers maximum speed and reliability. Built-in engineered rotational compliance ensures reliable coupling. And our common mounting flats are compatible with ATI’s vast selection of tool changer utility modules. ATI is also compatible with DeviceNet, Ethernet and Profinet. Which is
why more manufacturers say,
Hello ATI.
ATI.”
wwt cm 99 7 01
H
Hello
Fabrication: Punch Press
Function: Aids in assembly and reduces the need for jigs and fixtures.
Benefit: An additional stopping option.
Multi-Scribe
Function: Offers an unlimited range of sheet-marking options.
Benefits: Used for both sheet scribing and dot-matrix marking on a range of materials, eliminating the need to change tools each time produce a different mark. MF
H
   31   32   33   34   35
