Page 10 - MetalForming February 2010
P. 10
TechUpdate
Punch-Laser Combo Engineered to Optimize Throughput
Amada America, Inc., Buena Park, CA, introduces the LC-C1NT combination punch- laser machine, engineered to reduce the time required to transition a sheetmetal blank between modes from the typical 5 sec. down to as little as 2.2 sec. The cumulative effect of this time savings across a full sheet of nested parts, say company officials,
can easily add up to 2 min. or more per sheet of reduced run time.
In addition to the reduced tran- sition time, the C1 has been designed with new Y-axis punch- and laser- positioning drive modules that employ digital direct-drive servo motors, eliminating the need for gearboxes. This provides positioning accuracy to ±0.003 in., some 25 percent more accurate than machines that use a gearbox in their Y-axis drives,
the company says.
Amada America, Inc.: 877/262-3287; www.amada.com
Machine-Foundation
Experts Solve Press-
Pit Challenge for
Automotive Stamper
Progressive-die stamper and tool and die shop Wellington Industries, Belleville, MI, recently installed a 2000-ton press that required a unique foundation solu- tion. When preconstruction soil testing revealed a water-soaked sand base insuf- ficient to support the 1 million-lb. press, machine-foundation and press-pit experts Delta Industrial, Chesterfield, MI, exca- vated the site to remove the sandy soil.
The 22-ft.-deep excavation project required support by 30-ft. steel pilings; Delta pumped water from the pit through six well points. Then, after allowing the ground to dry, Delta used an epoxy-based non-shrink grout for the press pit that the firm says is five times stronger than concrete. During press installation, Delta
Counsel to the Metalforming Industry
Serving PMA Members since 1978.
EXPERIENCED EMPLOYMENT LAW
and
OSHA DEFENSE
AND THE DEFENSE WINS IN 2009
800.468.3464 (1-800-HOUDINI)
Construction Retro Refund Group
• Power Press Machine Guarding & LO/TO Diesetting Citations
• Refinery Fire & Chemical Accident Citations
• Bellevue Tower Crane Fatality Tip Over • Arc Flash Electrical Citation
• Roofing Employer Fall Protection
• LO/TO Program Citations
• Employment Discrimination Claim
• Dump Truck Tire/Wheel Separation
Citation
• Cities allowed to Join Workers’ Comp.
Fatality and Safety Program Citations
www.pma.org/ehlkelawoffices
Ehlke Law Offices
8 METALFORMING / FEBRUARY 2010
