Page 33 - MetalForming January 2011
P. 33
Tooling Technology
Rolei® BE5 Deburring Machine
• Simple, one-step operation
• 40, 60, 80 and 120 grit flap wheels
• 220 V or 440 V, 3-phase
Sheet with burr after cutting
Double-sided Deburring of Sheet Metal up to .2"Thick
Deburring o
both sides o the sheet edge
n f s
ture and includes an extra-large 165-mm- dia. diameter grinding wheel; an inner wheel cooling system that places coolant directly where needed, reducing exces- sive heat buildup; and a powerful 1050-W motor that delivers 4050 RPM for opti- mum surface finish. Grind depth can be set in 0.02-mm increments to avoid over-grinding.
Mate Precision Tooling: 800/328-4492;
www.mate.com/valugrind
Interactive Catalog a Sensor-Shopper’s Paradise
Banner Engineering, Minneapolis, MN, has released its 2010 interactive, online catalog, featuring its complete selection of sensor and safety prod- ucts. Users can browse the catalog page-by-page or use a powerful search tool to identify products by division, product family or name, model or part number, application or page number. Use it to shop for sensors, such as photoelectric, fiberoptic, special-pur- pose, ultrasonic and measuring array sen- sors; vision and vision lighting, including remote image sensors; wireless devices; and more.
Users can find details for featured products, such as support data, using the interactive page references. And, links throughout the product sections guide users to detailed information about acces- sories such as mounting brackets, retrore- flectors, enclosures and cordsets. Banner Engineering: 888/373-6767; catalog.bannerengineering.com
MultiMax is Ideal for All Workshop Grinding and Polishing Jobs
Multi-purpose bench grinder for steel, stainless steel and other metals – One machine uses all types of grinding discs and polishing wheel abrasives
Surface Finishing Solutions
1-800-700-5919 • www.csunitec.com
Heavy Gage
Specialist
50 presses up to 4,400 tons to serve your stamping requirements.
Try us— you’ll like us!
766 Research Pkwy., Rockford, IL 61109 rockfordtoolcraft.com
MetalForming/January 2011 31
