Page 49 - MetalForming May 2011
P. 49
• And More
The graphs show actual force/dis- tance performance of the last run. To the right are curves for each of the 12 cylinders.
Tonnage and distance are entered on the tonnage screen. The 12 bars on the right represent the 12 individual cylinders used in the cushion.
MetalForming/May 2011 47
New Products
also feature a durable fiberglass back and a semi-open coat that retards loading on aluminum.
Merit Metal flap discs feature an engineered blend of two high-performance zirconia products, cotton and polyester flaps, and provide superior cutting rate, long life and exceptional wear resistance.
Saint-Gobain Abrasives: 508/795-4435; www.nortonabrasives.com
Package Parts in This Plastic Netting to Prevent Rust and Corrosion
Industrial Netting, Minneapolis,
MN, introduces parts-separation
pads for use as an alternative pack-
aging material to cardboard and
other solids. The pads absorb fluids
and restrict airflow. Use them as a
separating layer—as bin liners, tote
liners, basket dividers and pallet
liners—between valuable parts to
minimize corrosion and protect from
chipping, scratching and abrasion.
Industrial Netting: 763/496-6355; www.industrialnetting.com
NEARLY 100,000 LISTINGS
OMITTHE DRAW BEADS
Save money with smaller blank size, even on high strength steel!
Since 1998, Red Stag has engineered a cushion which has the force and controls for all the flexibility you need for any high strength steel tooling.
info@machinetools.com ☎ 248.686.1520
twitter.com/machinetools Skype:MachineTools.com
A hydraulic cushion with total close loop control and programming with full control on each cylinder with the speed to change tonnage pressure and stroke eight (8) times from 3 o’clock to 6 o’clock. You now have control 360o from maximum blank holding pressure to start the draw-to-metal movement throughout the draw with a dwell on the bot- tom with higher pressure again. You can even remove all draw beads, make your blank smaller saving both steel and money.
RED STAG ENGINEERING
& AUTOMATION INC.
N2548 Meadow View Court,
Waupaca, WI 54981 U.S.A.
Phone: (715) 258-5074 Fax: (715) 258-5242 Email: redstag@waupacaonline.net Website: http://www.redstag.com
