Page 47 - MetalForming September 2011
P. 47
Metalforming Electronics
Vanishing
Oils
Oils
Oils
Oils
Oils
Oils
www.lamsonoil.com
HTT’s sensor test cart contains everything needed to test a sen- sored die in the toolroom.
Vanish Oil: The lubricant that removes itself from your formed parts.
Lamson Vanish Oils improve your stamping operation by eliminating the costly cleaning and disposal steps required with conventional oils.
Once applied, Vanish stays on the part through the stamping operation and then will evaporate. Within 30 to 45 minutes,your parts will be dry and on their way to assembly or shipping areas
Unlike other evaporating oils Lamson Vanish is completely odorless and contains no harmful chlorinated solvents. And Lamson Vanish can be used safely on most sensitive finishes and pre-coated stock.
Wittkopp is liberated to pursue his current projects with analog (or measuring) sensors, for use within fixtures and dies to ultimately guarantee required PPM levels based on actu- al dimensions of the parts as they are being stamped.
HTT is a beacon of error-proof metalforming and assem- bly excellence and serves as an example of how small to-mid- sized stamping shops can achieve the highest levels of sen- sor applications in our industry. Hats off! MF
MetalForming/September 2011 45
For detailed product information log onto: www.lamsonoil.com
or call 800-577-7895
