Page 22 - MetalForming June 2012
P. 22
Laser-Cutting Automation
sheets on the shuttle table (the opera- tor paces the system), it does improve efficiency—typically by 20 percent compared to a standalone hybrid machine. In a mixed-volume and medi- um part-variety environment, beam-on time will average 4.2 hr. per manned shift.
By adding a load/unload automa- tion system to a laser-cutting machine, the system can run unattended for pro- longed periods—the machine paces the system. The automation includes load and unload tables, which limits the fabricator to a single material type and thickness per setup. Therefore, this type of automation performs best in a batch-production environment with relatively few material changes. Load/unload systems can typically run 12 hr./day with one manned shift and one unmanned shift, providing 2.8- times the productivity of a standalone machine with a shuttle table. Such a system also can be used for single- or multiple-machine cells.
An FMS offers the greatest oppor- tunity to run unattended, because it enables a fabricator to use various material types and thicknesses while running unmanned. The design of an FMS includes multiple material-load- ing shelves for storing and loading material into one or more laser-cutting machines. An FMS shines when shops perform frequent material changes, as in a job-shop environment or within an OEM producing in relatively small batches. Machines equipped with an FMS typically experience 92-percent beam-on time with 14.7 hr. of cutting per day when running one manned and one unmanned shift.
3) What Should the Initial Configuration Look Like?
To configure an automation solu- tion, a fabricator must consider sever- al factors, beginning with machine type. A hybrid cutting machine has a single table that typically proves effec- tive for one or two machine cells pro-
cessing mild-steel sheet 1⁄4 in. or thick- er. Sheet-loading time will represent a smaller portion of total processing time, since cut time on this thicker material will be relatively high.
Pallet changers prove most effec- tive when cutting thinner material, or typically where more than two machines are needed in the automa- tion system. Here, a hybrid machine may have to sit idle while waiting for new material to be loaded. The sec- ond pallet on a shuttle-machine design operates as a buffer so that new mate- rial is loaded and ready for cutting.
Since most automation setups are modular in design, a fabricator can mod- ify the system as needs change, includ- ing the number of machines within the cell. Therefore, a fabricator can rest easy specifying a system based on near- term needs, knowing it can add to its automation solution as needed.
Consider these five variables when designing an automation setup:
1) Type of material storage required; 2) Number of machines in the cell; 3) Requirements of the material
transfer system;
4) Control methodology for the
automation system; and
5) Type of material-unload system. Material storage—Fabricators can
select from a variety of loading tables and material-storage shelves. A load/ unload system employs a single, fixed load table, or a scissor-lift table to accommodate more material. Specify a design with enough capacity to run unattended for the unmanned time- frame desired (overnight, for example).
An FMS offers the flexibility to store and load different material into the automated system. Shelves are stacked into a tower configuration, with each shelf storing a single material type and thickness. The shelves have individual weight limitations and total capacities for each tower. Depending on the man- ufacturer, tower configurations can hold as many as 20 shelves, and often towers can be grouped for even greater capacity.
Number of machines—Let the machine manufacturer specify the
Servo Press Technology ExperienceTM
www.metalformingmagazine.com/servo
6363 Oak Tree Blvd. | Independence, OH 44131 216/901-8800 | fax 216/901-9669
e-mail: metalforming@pma.org
Th
Interested in sponsoring? Contact Andrew Flando, aflando@pma.org
MetalForming magazine is offering suppliers to the metalforming industry an opportunity to reach executives, engineers and metalforming professionals, by sponsoring the Servo Press Technology Experience. The experience will include a series of 3 webinars and a live event at PMA’s headquarters in Cleveland, OH.
Webinar I: Servo Press Technology—
Applications for Today and Tomorrow
Thursday, August 23, 2:00-3:00 EST
Featured speaker: Dr. Taylan Altan, professor & director, Center for Precision Forming, The Ohio State University, Columbus, OH
Webinar II: Tooling Up your Servo Press Thursday, August 30, 2:00-3:00 EST
Webinar III: Marrying your Servo Press to a Metalforming System—Considerations for Controls, Feeds and Transfer Systems
Thursday, September 6, 2:00-3:00 EST
LIVE EVENT
September 19, Cleveland, OH (PMA headquarters)
Two sessions*: 8 a.m. to 12 p.m. and 1 to 5 p.m. *Repeated in the afternoon
An in-depth look at servo-press technology with case study presentations and breakout sessions with press builders/sponsors in private conference rooms.
e Official Publication of
Sponsored by:
20 MetalForming/June 2012
