Page 24 - MetalForming June 2012
P. 24
Laser-Cutting Automation
parameters. An MLC can provide pro- duction data that identifies what was cut, when it was cut and how long it took to cut.
Material unload—Similar to mate- rial-storage and loading options, fab- ricators can select from numerous con- figurations of fixed and scissor-lift tables for handling completed sheets. It is not uncommon to combine multiple offload tables so like-parts can be
stacked. The MLC can direct the tra- verser to move specific parts to a par- ticular table. Tables can ride on a rail system so they can be pulled from the cell for unloading without endangering operators. (Although we’re not address- ing fences, interlocks and other safety apparatus here, the machine manu- facturer will specify the safety equip- ment necessary to comply with gov- ernment safety regulations.)
Storage towers also can be added to an FMS, to enable separation of fin- ished work. Configurations and capac- ities are similar to the variety of load- tower options.
As you design an automation sys- tem, plan for growth and consider workflow layout, including material loading, unloading and other operations.
4) What Challenges Lie Ahead?
While implementing a laser- automation system will have a dra- matic impact on throughput, when incorporating existing laser-cutting machines into the system do not underestimate the lost production capacity during system build and inte- gration. Also, carefully consider down- stream operations relative to workflow and capacity.
Skilled labor also is an important component of the plan. While auto- mated-system operation will require fewer operators than will standalone machines, a few skilled people are crit- ical to oversee effective operation and to maximize throughput. Training must be a core element to implementation. Production expectations should grad- ually ramp up as the system comes online.
With a laser automation system fully operational, expect a dramatic impact on downstream operations—bending and welding, for example. Where laser cutting might have caused a bottle- neck, automation will eliminate it. But, if capacity for downstream operations does not increase, the bottleneck will simply shift. Therefore, you must devel- op a plan for handing the increased volume of laser-cut workpieces await- ing secondary operations. Initially, you may need to pace the lasers based on a pull approach from bending, welding and other downstream operations.
A final consideration is the attitude of everyone affected by the automa- tion system. Employees may fear for their job security, or mourn the loss of overtime hours. Gaining a certain amount of buy-in from the shop floor will enhance the likelihood of a suc- cessful project. MF
When I hand my son
the keys to this shop,
I want him prepared to succeed. Building a shop is
hard work, long hours, solutions under pressure. Building a legacy is guidance, experience, preparation. Which is why
I’ll be getting him off the shop floor and onto
the floor of the biggest manufacturing classroom
in the Western Hemisphere. Industry trends. New technology. Suppliers. Purchasing. Competitor demos and exhibits. He’ll be exposed to it all, face to face, in one place. Because someday, all too soon, this will be his place.
Dominate the competition.
Attend IMTS 2012. Register at IMTS.com
be there.
INTERNATIONAL MANUFACTURING TECHNOLOGY SHOW
Sept. 10-15 2012 · McCormick Place · Chicago
.com
22
MetalForming/June 2012
