Page 10 - MetalForming August 2012
P. 10
Clamshell Straightener Eases Maintenance for Wellman Friction Products
Coe Press Equipment, Sterling Heights, MI, recently installed a new clamshell-style Model CPPS-406-42 power straightener and a CPR-PO-15042 coil reel at Wellman Friction Products, Solon, OH. The manufacturer of friction components that go into brakes, transmissions, and clutches replaced exist- ing feed equipment on a 600-ton press line with the new straight- ener, to process material to 42 in. wide by 1⁄4 in. thick. The unit’s 30-hp AC variable-speed drive provides line speed to 60 ft./min., producing large clutch plates for use in earth-moving and farming equipment.
The straightener features an easy head-lift function that allows for maintenance and cleaning. Wellman expects that the unit will reduce downtime compared to the older unit, which required disassembly of the straightener head to clean the rolls. With the new straightener, the top rollers separate from the bot- tom rollers to provide access to the straightening rolls for inspec- tion and cleaning. Pushbutton controls are used to activate hydraulic cylinders that raise the head containing the top rolls.
The CPPS-406 model features 4.0-in.-dia. straightening rolls and 6.3-in.-dia. pinch rolls. Other features include a nine-roll straightener, an alligator-style peeler for effective dekinking and threading operations, and independently adjusted powered coil
guides for effec-
tive coil loading
and guiding.
Wellman also
opted to include Coe’s
LoopMaster laser loop
control, a non-marking
chrome roll package, sin-
gle row straightener backup rollers,
self-centering hand-crank entrance edge
guides and a Trabon automatic-lubrication system. Coe Press Equipment: 586/979-4400; www.cpec.com
Mixing Machines and Metal Art
When metal artist Dick Roberts discovered Torchmate CNC plasma-cutting machines, the hours he spent hunched over aviation snips, and the days of laborious repetition with a hand- held blowtorch, went out the window. Working out of his garage in Fort Myers, FL, Roberts fabricates intricate steel, cop- per, aluminum and stainless-steel art pieces. His Torchmate
ONE EVERYTHING COMPANY. YOU NEED.
WHEN IT COMES TO ABRASIVE WATERJET MACHINING,
OMAX Corporation has everything you need.
OMAX is a single-source provider of the industry’s most innovative abrasive waterjet technology. With the OMAX and MAXIEM lines of waterjet equipment, we offer a complete range of capabilities from industry standard to high performance.
When it comes to waterjets, OMAX is the only partner you need.
WWW.OMAX.COM 1.800.838.0343
WWW. MAXIEMWATERJETS .COM 1.877.629.4365
Connect and follow OMAX for the latest news in waterjet technology.
Facebook
Twitter
LinkedIn
8 MetalForming/August 2012
