Page 12 - MetalForming August 2012
P. 12
Safety Update
Stand-Alone Safety Controller Delivers Flexibility and Power Pepperl+Fuchs, Twinsburg, OH, introduces the
VAS-2A8L-KE4-8SE programmable safety con- troller—cost-effective, adaptable and easy to install, configure and run. The device, say com- pany officials, bridges the gap between low-end safety relays that can’t adapt to evolving appli- cation needs, and high-end options designed for larger systems and too costly for smaller appli- cations. The safety controller provides four redundant safe inputs and two independent safe electronic outputs; an expansion port enables the controller to grow with the application. It runs on standard 24 VDC and allows any safe device with dry contacts or electronic safe outputs to be used.
“The market is flooded with safety relays and
configurable safety controllers that can get
the job done,” says Helge Hornis, manager, intel-
ligent systems group. “Most of the higher-end
ly for all but the largest and most difficult applications, while low-end controllers lack the flexibility to adapt when application requirements change, even just a little.”
Connecting safety devices to the controller merely requires wiring a conven-
tional safety relay; removable terminals simplify installation and field service. An intuitive drag-and-drop application interface makes it easy to configure even complex safety operations in just minutes.
Pepperl+Fuchs: 330/486-0001;
www.pepperl-fuchs.us
Omron STI Inaugurates OEM Partnership Program to Ensure Machine Safety
A new OEM Partnership Program offered by Omron Scientific Technologies, Inc., Fremont, CA, enables machine designers to partner with the company to ensure that they employ the proper machine safeguarding and that their machine designs will be correctly safe- guarded to all current standards. Omron STI, which provides safeguarding products
10 MetalForming/August 2012
solutions are too complex and cost-
