Page 36 - MetalForming October 2012
P. 36
Educational Program
greater productivity on your slit- ting line with new innovations, such as CNC slitter-head control, slitter-head tooling setup and vac- uum roll strip tensioning.
Advances in Blanking
A lot of confusion remains regard- ing blanking: What is the proper way to measure blanks, what types of CTL/blanking lines are best suited to produce the most accu- rate parts, etc? This presentation will discuss common questions and misperceptions.
Plate Fabrication
Lifting Magnets—Choosing, Using and Benefitting
Understand the basics of magnetic material handling, everything from how magnets work and the differences between the various types of magnets to the potential applications for lifting magnets.
Plate-Rolling Fundamentals— How to Get the Job Done
Learn the basic principles of roll technique, material thickness vari- ances and tips to help become more effective in rolling material.
Better Holes with Plasma: What You Need to Know to Take Hole Cutting to the Next Level
While many acknowledge the diffi- culties in using plasma for hole cutting, advancements in technol- ogy have enabled a way to signifi- cantly improve hole quality while lowering operating costs.
1:30 p.m.–3:30 p.m.
Advancements in Leveling Technology Changing Shape of Flat Rolled Metals
The secret to upgrading the flat- ness of flat rolled metals is to understand shape defects and basic metallurgy determining material behavior.
Laser-Quality Metals—How?
Learn how to process perfect
laser-quality sheetmetal.
Beyond Coil—The Unique Challenges of Leveling
Flatter parts can reduce manufac- turing time, lower product costs and produce parts with tighter tol- erances. This presentation explains the options for leveling, flattening and straightening, and describes best practices.
New Innovations in Leveling
With the increased use of lasers, it is more important than ever that material is flat. Understand the latest technology available for measuring flatness.
Using Robotics in Metalforming and Fabrication Getting Started with Robotics
Learn the pros and cons of intro- ducing robots into your operation, and how to evaluate robotic equipment and suppliers.
Rock Valley
Oil & Chemical Co.
World Class Stamping Lubricants Global
Consumer Products
Structural Components
HSS/HSLA, Aluminum
Hydroforming, Deep Draw
See us at
34 MetalForming/October 2012
ISO 9001:2008 Booth C1049
Rock Valley Oil & Chemical Co. 1911 Windsor Road
www.rock alleyoil.com www.metalformingmagazine.com
