Page 38 - MetalForming October 2012
P. 38
Educational Program
Robotics—State of the Industry and Technology
Wednesday, November 14
8:00 a.m.–10:00 a.m.
Maximizing Your Press Brake
Maximizing Press Brake Productivity
Learn how the latest technologies available on the market can help
maximize press brake productivity.
Double Your Output
This presentation will show you how to rethink the way you form parts, by purchasing the right options on a press brake.
Stamping Track
Monday, November 12
Brawn.
Dallas Press Feeding Equipment lasts and lasts for many years because we design and build everything to handle more than the specified material. In simple words, when you buy a Dallas line you buy it fully equipped with heavy gauge materials and without the need to add a lot of options. And, because Dallas machines are built to last, we can easily upgrade them with the latest control packages, upgrading the Brains... without a lot of work on the Brawn.
Standard Equipment & Complete Systems
Tool Steels to Improve Die Life
Use of Surface Engineered Pre-hard HRC 45 Tool Steel in Forming Applications
Learn the results of laboratory tests pertaining to the influence of die surface conditions on die adhesive wear when forming 0.95- mm thick DP 600 sheet.
A New Tool Steel for High- Toughness High-Wear Tools
PM-manufactured tool steels have traditionally offered higher wear resist- ance alternatives to D2, M2 and other conventional tool steels. This presen- tation will discuss the development and properties of a new grade, and relate its properties to failure modes and performance expectations.
Improving Business Results through Effective Cost Models and Training
Metalforming Pioneer: Development and Implementation of Press Operator Training Program
Listen as an award-winning com- pany describes the development and application of an internally developed, comprehensive Auto- matic Press Operator Training Pro- gram and a new Technician Train- ing Program.
Metalforming Pioneer: Inhouse Training|Cross-Training|Project Management
A metalformer describes its inter- nal training program, emphasizing cross-training, training metrics and career paths.
Purchasing Practices and Trends in Utilizing “Should Be” Cost Models when Evaluating Stampings
This is an overview of the various ways cost engineers/estimators develop “should-be” cost models, and how buyers use these models to analyze and benchmark suppli- er quotations.
10:30 a.m.–12:30 p.m.
Introduction to Formability Engineering and Analysis
An introduction to the Science of
Brains.
DallaSmartTM controls minimize electrical and mechanical stress on equipment and material. Whether you are buying new or upgrading existing equipment, they allow you to operate at higher speeds, run larger parts, eliminate surface damage, reduce wear and tear on equipment and material. ProfileSelectTM, our newest offering is ideal for delicate material and progressive die work. The control uses a sinusoidal motion that utilizes 100 percent of the press-feed window.
DallaSmartTM Controls
• ProfileSelectTM Servo Feed Controls
• Replacement Control Upgrades
• Laser Coil Positioning with Readout
• Automatic Reel Brake Controls
• Synchronized Controls of Complete Lines • Name Brand Drive Controls
• Press and Feed Line Integration
• Communication Integration
50,000lb x .135 x 72 wide HSLA
dallasindustries.com 248.583.9400
• Servo Feeds
• Press Feed Lines
• SpaceSaverTM Feed Lines • Straighteners-Powered • Straighteners-Pull Thru • Cradle Systems
• Reel Systems
• Air Feeds
30,000lb x 1⁄2 x 20 wide HSLA
1962-2012
36
MetalForming/October 2012
