Page 12 - MetalForming March 2013
P. 12
Software Add-On Monitors Waterjet-Cutting Performance
Omax Corp., Kent, WA, used the IMTS 2012 stage in Octo- ber to introduce its Intelli-Visor system-monitoring package, designed to enable users to oversee the status and perform- ance of their Omax abrasive waterjet throughout the cutting
parameters, including cutting activity, pump pressure and abrasive levels, and also track machine hours and maintenance schedules.
The software also enables an operator to specify what param- eters need to be monitored, and the actions the machine should initiate should an operation fail or approach failure. These actions include pausing the machine to protect the cutting head and workpiece, and administering an alert notification. And, with an Internet connection, Intelli-Visor can distribute an alert notice to as many as four people via e-mail or text messaging. Omax Corp.: 800/838-0343; www.omax.com
New Think Tank for Advancing Metalforming and Forging Processes
EWI, Columbus, OH, has established the EWI Forming Cen- ter, to develop new metalforming and forging processes and sup- port U.S. manufacturers as they strive to apply new advanced materials and net-shape forming methods, and improve structural performance. The center offers expertise in testing, modeling and simulation-based engineering, and recently welcomed a 160-ton press. It will cooperate with the Ohio State University
process. Intelli-Visor works to increase the efficiency and uptime of any Omax JetMachining Center by connecting oper- ation controls with machine maintenance.
As a function of the Omax Intelli-MAX 18 control software, Intelli-Visor uses an industry-standard Modbus communications protocol, a streamlined software interface and robust network of machine sensors to capture and share real-time data from different components across the JetMachining Center. As a result, operators can effectively monitor and analyze machining
Tailor Welded Co
Tailored products for coil fed operations such as; progressive die, roll forming and coil fed transfer presses
TWB Company
oi
: Unlimited Possibilities
il
ls
s:
Tailor Welded Coil
The new light weight steel
progressive die
roll forming
wide coils
P:734.289.6400 • sales@twbcompany.com • www.twbcompany.com
10 MetalForming/March 2013
