Page 14 - MetalForming March 2013
P. 14
to ensure reliability and account for potential variations in material properties. With ALC, the cutting process automat- ically adjusts to changing conditions, processing at the highest possible speed with optimum efficiency. This avoids the need to restrict or control cutting speed, reportedly providing as much as a 10-per- cent increase in productivity.
ALC now is a standard feature on select models of the firm’s Impuls Series laser-cutting machines.
LVD Strippit: 716/542-4511; www.lvdgroup.com
Stamper Overcomes Slug-Pulling Hurdles
Early in 2012, Bloomingdale, IL-based Bi-Link, a provider of stamped metal and injection-molded parts, finally found the slug-pulling solution it was looking for—a Slug Keeper slug-retention machine
developed by DTC Products, a division of Dec Tool Corp., St. Charles, IL. Bi-Link toolroom supervisor Scott Bedow had grown tired of watching as slugs pulled back onto die blocks during stamping. This pesky problem caused unplanned downtime and associated costs as press- es stopped so operators could remove slugs and inspect parts and dies for dam- age. Now, Bedow reports that the slug- retention machine has virtually elimi- nated slug-pulling events.
The slug-retention machine uses a pneumatically powered grinder to precisely machine a small angled groove into the sidewall of a stamping-die cavity. A micrometer coupled to the drive of the machine’s slide enables precise move- ment of the machine’s carriage to con- trol the depth of the slug-retention groove. The groove creates a precise amount of interference so that during stamping, the slugs expand into these grooves to prevent them from being
pulled back up to the top of the die block and onto the die surface.
Bi-Link primarily employs the machine when stamping thicker stainless-steel medical components as well as auto- motive parts of high-strength low-alloy steel. Run at high volumes, dies to stamp these parts typically feature full- carbide inserts and punches, expensive to manufacture and therefore worthy of protection from the damage that pulled slugs can cause.
The slug-retention machine meas- ures less than 10 in. high, and features a magnetic base so it can mount tem- porarily but firmly in place on the die sur- face during the grooving operation. “The nice feature with the machine is that we don’t have to tear each die apart and set up one block at a time in the machine,” says Bedow. “Instead, we just move it down the line in the die.”
DTC Products, a division of Dec Tool Corp.: 866/682-3602; www.dectool.com
UNIQUELY YOURS
UNIQUELY YOURS
100 and 50 ton press cell for precision assembly of safety-critical inline ball joints. Motion con- troller and PLC govern 3-stage ram downstroke. Electronic servo control with precision feedback, together with a pressure transducer and linear transducer maintains 1% of force and .0015” tolerance on ram contact position.
Customized hydraulic presses engineered to meet YOUR needs and YOUR shop floor technology.
We work with you to design electronical- ly-controlled special-purpose presses that consistently produce high-quality parts and globally competitive productivity.
Call Gene at 614-228-0185, ext. 231 for details and an eye-opening quote.
sales@multipress.com www.multipress.com
12 MetalForming/March 2013
