Page 13 - MetalForming April 2013
P. 13
With over 35 years hydraulic press engineering experience, Magnum Press Inc. builds standard and custom hydraulic presses and continues to be in the business of making sure you get the right press for the job. Magnum offers a full line of HIGH SPEED standard gap frame press models in classic C-Frame configuration, 2-Post and 4-Post Guided Tool Plate, Heavy Duty GIB Guided and economical Compact Models. Custom 2-Post and 4-Post Column Style presses are quickly designed and built to your specifications. Magnum Press Inc. has the press for you!
www.magnumpress.com
thick stainless-steel plate, and leaves a slight 1- to 3-deg. bevel on thick plate, compared to a 7- to 10-deg. bevel using standard plasma-cutting technology.
Interplex Adds Overmolding to its Skill Set in Hungary
Automotive and electrical-industry supplier Interplex Hungary, a division of Interplex Industries, College Point, NY, has added a 30-ton overmolding line to its metalforming and assembly facility. Its first overmolded parts will be a range of automotive connectors; production should launch during the first half of 2013. The line is part of an expansion phase at the plant, in Kunszentmarton, that includes a 40-ton vertical press as well as two 150-ton presses scheduled to be installed early in 2013.
Minnesota Waterjet Shop Adds Four-head Cutting Machine
Precision Waterjet Concepts Inc., Pequot Lakes, MN, has installed its third waterjet-cutting system from Jet Edge Inc., St. Michael, MN, this one a 4- by 4- ft. gantry machine equipped with four abrasive-jet cutting heads and a 150-hp intensifier pump. Precision Waterjet Con- cepts has grown 20 to 30 percent per year since opening in 2002; its 19,000- sq.-ft. shop houses three 3-axis waterjet systems and three 5-axis systems.
ATW Companies Consolidates Firearms Operations
ATW Companies has relocated the gun-magazine manufacturing operations of its Metalform division from New Britain, CT, to its headquarters facility in Warwick, RI. Metalform’s process capa- bilities include deep drawing, stamping and pistol-magazine (38- and 45-caliber and 9-mm) fabrication. ATW, which acquired Metalform in 2011, performs CNC machining, metal-injection molding, laser cutting and stamping.
ETA Opens So-Cal Office
Engineering Technology Associates (ETA), Troy, MI, developer of the Inven- tium Suite of modeling, stamping and simulation software, has opened an office in Los Angeles, CA. The new office
will provide simulation and analysis serv- ices for regional OEMs and suppliers in the hybrid and EV vehicle, aerospace and electronics industries.
Precision Cylindrical-Grinding Services for Steel Fabricators and Coil Processors
The maintenance and repair facility of Menges Roller Co., Wauconda, IL, has expanded its service offerings to include precision cylindrical-grinding services. The facility is equipped to breathe new life into straightener rolls, work rolls, flat- tener rolls and other related equipment. It can regrind rolls as large as 24-in. dia. and 20 ft. long.
Baird is Manufacturing Fourslides and Transfer Presses
Baird Machinery Corp. announced that it now is building the new Nilson Model 1- FB fourslide at its plant in Thomaston, CT, in the 700L, 751, 2-F and 3-FB models. It’s also building new U.S. Baird transfer presses in models 2-19, 3-25, 3L-25, 3L-37, 3L-45, 4-44,4-56, 5-51, 5-60 and 5L-51.
Ten New Coil-Processing Lines— Three of Them Zig-Zag Equipped— Headed to North American Stamping Group
Coe Press Equipment, Sterling Heights, MI, has received an order for 10 coil-processing lines from North American Stamping Group, for its facili- ties in Portland, TN; Woodstock, Ontario, Canada; and Queretaro, Mexico. Among the lines, seven are conventionally equipped for progressive-stamping oper- ations, and three feature zig-zag servo- feed capabilities.
Architectural Fabricator Adds 12-ft. Press Brake
SAF-West, Redding, CA, an aluminum distributor and fabricator focused on supplying the architectural market, has added a 175-ton 12-ft. AccurPress press brake to its fab shop. The new brake comes on the heels of the firm’s new anodizing line, and complements its existing capabilities including shearing, welding and routing.
MetalForming/April 2013 11
News Fronts
