Page 14 - MetalForming April 2013
P. 14
Vanishing
Oils Vanish Oil: The lubricant that removes
News Fronts
itself from your formed parts.
Lamson Vanish Oils improve your stamping operation by eliminating the costly cleaning and disposal steps required with conventional oils.
Once applied, Vanish stays on the part through the stamping operation and then will evaporate. Within 30
to 45 minutes, your parts will be dry and on their way to assembly or shipping areas.
Unlike other evaporating oils Lamson Vanish is completely odorless and contains no harmful chlorinated solvents. And Lamson Vanish can be used safely on most sensitive finishes and pre-coated stock.
Oils
www.lamsonoil.com
Harrington Hoists’ Growth Spurt
The manufacturing plant in Manheim, PA, which has served as the home of Har- rington Hoists, Inc., no longer is large enough to support the company’s growth, so the firm has leased a 97,000- sq.-ft. facility in Elizabeth- town, PA, to house its ware- housing and assembly operations. The new facility should be operational by May 2013; operations, fabrication and production manufactur- ing remains at the Manheim plant. Harrington Hoists man- ufactures electric-chain and wire-rope hoists, air-powered hoists, lever hoists, trolleys, cranes and other products.
Graebener-Reika Sets Up Shop in PA
A 12,000-sq.-ft. facility in Reading, PA, is the new home of the engineering, sales and service staff of Grabener-Reika, Inc., a manu- facturer of a variety of fabri- cating equipment for tube, pipe, plate and sheet. The firm, a joint venture between German companies Graeben- er Machinintechnik and Reika, and Automatic Feed Co., Napoleon, OH, manufac- tures hydraulic, hydroforming and hot-stamping presses, pipe-bending and end-bevel- ing machines, and much more.
Rollformer Opens Third Shop,
This Time in Las Vegas
American Roll Form Prod- ucts, Painesville, OH, a man- ufacturer of custom roll- formed products, has opened a 40,000-sq.-ft. plant in North Las Vegas, NV, to support customers and
projects located in the South- west. Two rolling mills began operating in March; a third mill is scheduled for startup in June.
Metal Supermarkets to Open Third Dallas-Area Store
Fabricators, tool and die makers, machine shops and other buyers of small quanti- ties of metal-alloy products in the Dallas-Fort Worth, TX, area soon will have a new store to shop at, as Metal Supermarkets has begun a sight search for its third store in the area. When the new store opens this spring, it will be the franchise’s 67th location.
Arku Leveler Headed to Mayville
To reduce scrap resulting from uneven sheetmetal parts that caused welding and forming problems, Mayville Engineering Co., Mayville, WI, has purchased a FlatMaster 55 precision leveler from Arku Coil Sys- tems Inc., Cincinnati, OH. The leveler is rated for mate- rial to 1⁄2 in. thick. Mayville Engineering performs sheet- metal and plate cutting, form- ing, stamping, machining, welding and assembly.
Metrology Application Center Doubles in Size
Mahr Federal has more than doubled the size of its application center at its headquarters in Providence, RI, offering an expanded range of development activity based on its lineup of dimen- sional gaging and metrology equipment. Included is an area with a large granite sur- face plate, allowing engi- neers to work with a variety
Oils
Oils
Oils
Oils
For detailed product information log onto: www.lamsonoil.com
or call 800-577-7895
12 MetalForming/April 2013
