Page 29 - MetalForming July 2013
P. 29
The Heim Group...
A Family of Performers
The Heim Group has been designing and manufacturing presses for more than 65 years. Our Heim and Rousselle
press brands are known worldwide for their quality construction and perform- ance. Built in our Chicago fac- tory, using American-made components whenever possi- ble, our presses have a rep- utation for dependable oper- ation, competitive price and superior support from our dealers and inside staff.
Each Maxi Stamper straightside press is engi-
neered with the latest CAD technology and built by our experienced craftsmen.
Every aspect of the machine
is manufactured with high- performance unmatched accuracy for years of reli-
able use in your opera-
tion.This series of eccen- tric-geared tie-rod
straight-side presses is available in the 300- to 1000-ton range.You select the stroke, speed, shut height and bed area. Standard drive rating is 0.500 in. above bottom stroke, but other options are available to meet your appli- cations and energy requirements. Likewise, customers may select a more rigid frame deflection from the standard 0.002 in./ft. Please see our website for details.
Smaller press requirements are served by our Maxi Stamper II series of C-frame, front-to-back shaft designed presses in the 90- to 300-ton range. Built with the same heavy-duty standard designs, these presses have simi-
lar features and performance to our straightside presses. Maxi Stamper II presses also are offered in a solid frame design for applications sensitive to frame deflection.
Happy 25th anniversary, MetalForming!
Scan to see our presses in action! http://bit.ly/heimvideos
6360 W. 73rd. St. Chicago, IL 60638 708/496-7400
Fax: 708/496-7428 www.theheimgroup.com info@theheimgroup.com
MetalForming/July 2013 27
ADVERTORIAL
