Page 15 - MetalForming February 2014
P. 15
Mix and Distribute High-Viscosity Lubricants at Up to 500 psi
Lubrication-equipment man- ufacturer Industrial Innovations, Wyoming, MI, has introduced its new generation of Spra- Rite lubricant proportional-mix- ing machines (Pro-Mix). Stam- pers can use the Pro-Mix machines to blend synthetic, semi-synthetic and emulsified lubricants at multiple dilution ratios.
voirs for stabilizing liq- uids prior to mixing and a patented Pro-Drive assembly for thorough mixing, control and pres- surizing of the lubricant mixture. Additionally, fluid-level status indica- tors continuously monitor the level of the two fluids, and refill on demand or discontinue service if levels reach a low level during operation.
Pro-Mix systems can be connected to a network of piping to automatically deliver a continuous supply of pressurized lubricant mixtures to multiple presses. The systems feature stainless-steel reser-
lockout feature that ensures mixture ratios are set for consistency without modification.
Industrial Innovations: 616/249-1525; www.industrialinnovations.com
The machines feature a
new controls package that can
run single or multiple machines
and distribute at pressures
as high as 500 psi, making
them a good solution for mix-
ing and delivering high-vis-
cosity lubricants. A new operator touch- screen and in-depth maintenance notification system built into the HMI make this a comprehensive and user- friendly system.
As in previous gen- erations, the machines come in three models, all with an operator
Don’t let the precision die components be the piece in your manufacturing puzzle that prevents you from keeping your lines
up and running.
Automation Details Ball Lock Buttons
a
B
B
all Lock Retainers • Blade Punches Cut-off Dies • Die Inserts
Die Components Headed Punch Retainers Headed and Ball Lock Punches
Headed and Headless Die Buttons
H
C
ustom Details • Roll Form Details
C
u
Contact us today for all your precision tooling for stamping, roll forming and metalforming.
800.243.1492
www.AmericanPunchCo.com • info@AmericanPunchCo.com
A FAMILY OF PERFORMERS SINCE 1946
Rousselle presses are offered in single point gap, two-point gap, two-point straight side and adjustable bed styles from 15-400 tons. All presses carry
THE HEIM GROUP reputation for American-made design, engineering and quality to your operation. Competitively priced and backed by an unmatched package of service, fast part delivery and even custom modifications to standard models, so the press you buy is the press you really need. LET HEIM HELP!
Visit www.theheimgroup.com today for the whole story!
Can’t wait? Call 1-800-927-9393
MetalForming/February 2014 13
