Page 13 - MetalForming June 2014
P. 13
   Plasma-Cutting Kits
Combine Torch,
By offering objective, quantitative feedback on key performance parameters, the sys- tem promotes trainee independence and learning, and allows users to gain the proficiency needed for skilled welding opportunities. The preweld simulation mode avoids waste- ful consumption of weld coupons, gas and wire and provides a sound welding-technique baseline for accelerating training when live welding occurs.
Consumables
Featuring a touchscreen monitor, LiveArc guides a welding trainee from assignment selection to simulated welding practice. It includes Miller-designed assignments, and allows welding instructors to easily develop additional assignments with customized param- eters for specific weld joints and positions.
American Torch Tip, Bradenton, FL, introduces its PHD 260X and 400X plas- ma-cutting kits, featuring 260- and 400- A component sets that include a quick-dis- connect torch, consumables and more. Components (10 electrodes, 10 nozzles, two swirl rings, etc.) are compatible with HPR 260XS and 400XD apparatus. Use the equipment to cut mild and stainless steels and aluminum alloys to 45 mm thick. American Torch Tip: 941/753-7557; www.americantorchtip.com
An industry-exclusive 400-A SmartGun features built-in LEDs that the system’s camera tracks in order to provide feedback on technique parameters, including work and travel angles, contact tip-to-work-distance, travel speed and aim. The gun’s display screen provides initial feedback to guide the trainee in proper gun position, and integrated push- buttons act as a convenient alternative to touchscreen navigation. A joint calibration tool informs the system of joint location, which allows the user to place the weld coupon in nearly any position.
Reality-Based Welding Training System Provides Fast, Accurate and Cost-Effective Results
As the need for skilled welding operators grows, Miller Electric Mfg. Co., Appleton, WI, aims to help build welder skills with its new LiveArc reality-based training system. The LiveArc system features advanced motion-tracking technology that provides critical feed- back to improve welding skills, providing fast and cost-effective results.
Miller Electric Mfg. Co.: 800/426-4553; www.millerwelds.com
FINANCING
        1-310-453-6981 INFO@SUTHERLANDPRESSES.COM WWW.SUTHERLANDPRESSES.COM
www.metalformingmagazine.com MetalForming/June 2014 11
   11   12   13   14   15
