Page 48 - MetalForming October 2014
P. 48
Down with Downtime!
Previews
Hydraulic Presses for a Host of Applications
Greenerd Press & Machine Company Booth B1355
Up your uptime with redundant sensors and Delta.
Delta’s motion controllers
provide a multitude of feedback options, including input from redundant sensors. Now when a sensor fails, your system can keep running.
See a demo and get
a free Design Guide.
Just call 1-360-254-8688 or visit deltamotion.com
Greenerd will showcase its extensive hydraulic-press capabilities and have application experts available in the booth
to discuss specific user applications and
press requirements. Stop by to discuss its recent installation of a 100-ton four-post hydraulic press for sizing metal rings on
the inside diameter after a welding process. The stroke on this press is adjustable to a maximum of 12 in., and
ram speed can be adjusted depending on
the process. Greenerd presses are avail-
able in a variety of styles with capacity to 40,000 tons and bed sizes exceeding 240 in.
www.greenerd.com
Weldments, Plate, and Die Sets
Plant-Wide Die-Lubrication and Application Systems
Anchor Danly Fabrications Booth B1241
Anchor Danly has enhanced its ability to provide complete fabrication services. At its booth, take a look at machined plate and fabrications, and watch plant-floor video footage that will showcase its large-scale capabilities such as the SNK RB-6VM mill (checking in at X236/Y137/Z80). www.anchordanlyfabrications.com
Industrial Innovations Booth B1311
Industrial Innovations will highlight the benefits of plant-wide die-lubricant distribution and application systems, and display its Pro-Mix proportional mixer, Spra-Rite applica- tor system (utilizing the patented Z-Drip nozzles), and a Reclaim-Pro recla-
mation system.
Pro-Mix systems can
1-2 Axis
Multi-axis
blend synthetic, semi- synthetic and emulsified lubricants at multiple dilu- tion ratios. In a plant- wide or closed-loop sys- tem, the lubricant mixture is distributed from the mixer throughout the manufacturing facility via an in-plant piping net-
46
See us at FABTECH booth B1337 MetalForming/October 2014
work, for use at each press using the Spra-Rite applicators. These units feature inde- pendently controlled ejector valves that enable precise regulation of the lubricant vol- ume and placement, at predetermined press-stroke intervals, at specific areas of the stamping or drawing tools or on the stock. Used lubricant then can be collected, cleansed and recycled using the Reclaim-Pro units, which rely on MSR coalescing plate separators to remove oil from the lubricant. www.industrialinnovations.com
