Page 50 - MetalForming October 2014
P. 50
Previews
Metalworking and Metalforming Fluids of All Types
Falcon Industrial
DuraDraw 6500 Series extreme-pres- sure lubricants represent a major advance- ment in synthetic metalforming technology and tackle the challenges associated with producing heavy-gauge drawn and stamped parts. DuraDraw 310 is a high-performance water-soluble drawing and stamping fluid for deep drawing, stamping, punching and blanking of carbon and stainless steels. It is specially formulated to pro- vide excellent rust protection, hard-water
Booth A2549
The team at Falcon Industrial, Inc. will present to FABTECH attendees its pre- mium drawing and stamping fluids DuraDraw 6500 Series and DuraDraw 310, and its Falconite 9192 welding antispatter compound.
stability and biological control.
Falconite 9192 was specially formulated
48 MetalForming/October 2014
to provide optimum antispatter protec- tion while containing only nonhazardous components. The unique water-based for- mula keeps welded surfaces cooler, helps prevent bowing and significantly reduces labor and downtime associated with grind- ing, cleaning and equipment changeout.
www.falconindustrialinc.com
Gear Couplings for a Host
of Fabrication Applications
Desch Canada Booth B1413
Desch gear couplings are flexible-shaft connections suitable for a positive-torque transmission. They’re designed to com-
pensate for radial, axial and angular shaft misalignments. The gear couplings are made of steel with grease lubrication and O-ring seals.
Desch gear couplings are used in all areas of mechanical engineering and offer a long service life with maximum reli- ability, resulting from the optimal grease lubrication of the crowned spline. The couplings are generally suitable for hori- zontal assembly; special types are suitable for vertical assembly. Use them for shaft diameters from 20 to 1000 mm.
www.desch.de/en
