Page 52 - MetalForming October 2014
P. 52
Previews
New Line of Press-Brake and Punch Press
Tooling, Laser Consumables
Control-Reliable Valve
for Cylinders
Mate Precision Tooling Booth B3301
Ross Controls Booth B1107
Mate will exhibit its new European and Wila Trumpf- style press-brake tooling, which includes a full array of punches, dies and specials available in seg-
mented, full-length and half-length
sizes. Wear surfaces of the punch-
es and dies are induction hardened
for durability.
Ross Controls will showcase its new line of four-way control-reliable valves for double-acting cylinder or cylinder press applications. The CM2 series is a Category 4 PL e device and offers a self-contained dynamic monitoring system, valve fault lockout for added safety and independent reset for precise control of hazardous operations.
Also on display: Mate’s new
Versadie insert slitting die that
takes clamp clearing to a new level.
It reduces material cost and
waste for slitting operations by
punching closely to the
clamps, crucial when maximum
sheet usage is required. The die also allows users to replace inserts without replacing the entire slitting die.
CM2 valves feature built-in tamp- er-proof silencers and optional pres- sure-switch feedback signals to the machine controls. The flexible base- mounted design can be used inde- pendently or in multiple-manifold con- figurations. Ideal for moveable barrier guards, critical clamping operations or cylinder press control, the CM2 series is available in port sizes from 1⁄4 to 3⁄4 in., in a variety of thread types.
Booth visitors also can meet with Mate’s sales engineers to discuss support for form- ing applications and special-shape tooling for forming card guides, embosses, thread forms and hinges.
And, last but not least, check out the firm’s Peak, Black Magic and Performax CO2-laser lenses, and fiber-laser lenses, nozzles and mirrors. www.mate.com
www.rosscontrols.com
FAMILIAR MILL.
UNHEARD-OF LEAD TIMES.
LOOK TO US FOR LIGHT-GAUGE STAINLESS STRIP TURNED LIGHTNING FAST.
Heyco Metals is your dependable source for high-quality, Light-Gauge Stainless Steel, delivered to your exact specifications. Our decades of experience, sophisticated QC technology and dedication to customer service set us apart. You’ll benefit from:
Precisionprocessing
Shortleadtimesforcustom-rolledproduct
Outstandingtechnicalsupport
95%-pluson-timedelivery
100%CognexVisionSurfaceInspection
StretchBendLevelingtoassurestripflatness&shape
For stainless orders of all sizes – as well as copper and copper alloy strip – you know where to turn. Learn more at www.heycometals.com.
800-57-HEYCO sales@heycometals.com ISO9001: 2008 Registered
Scan to learn more.
©2014 HEYCO Metals, Inc.
50 MetalForming/October 2014
