Page 12 - MetalForming November 2014
P. 12
The F-150’s Aluminum
Secret to Success: Heattreating
An expansion of the part- nership between Al-Fe Heat Treating, Saginaw, MI, and Ford forms the foundation of the 2015 Ford F-150. Al-Fe Heat Treating is investing millions of dollars in its Saginaw plant in part to process structural parts for the all-new military-grade aluminum alloy and high-strength steel F-150. The investment allows Al-Fe to perform the pre- cision air-quenching (PAQ) heat- treating process to the alu-
existing continuous age oven, to com- plete the artificial-aging process.
minum, which offers significant benefits, say company officials, compared to traditional quenching methods. The PAQ process provides the required mechanical properties while controlling and minimizing distortion.
To further enhance its service and support the end goal of eliminating unplanned downtime for Beckwood machine owners, Beckwood Press, St. Louis, MO, has introduced TechConnect— a remote connectivity system designed to offer complimentary offsite, factory-pro- vided diagnostics and troubleshooting of its hydraulic presses and Triform hydro-
Al-Fe also is partnering with Can-Eng International, Niagara Falls, Ontario, Canada, to upgrade and customize the controls on Al-Fe’s continuous solution furnace, as well as build and install the PAQ system. In addition, Can-Eng will assist in adapting the con- figuration of the automated conveyors, delivering the parts immediately to Al-Fe’s
A FAMILY OF PERFORMERS SINCE 1946 ...
Says John Holifield, Al-Fe vice president of heat treating operations: “Precision air quenching is a process that allows automotive part manufacturers to build frames, engines and other parts out of alu- minum and steel, marrying the best of strength and lightweight design into one.” Al-Fe Heat Treating: www.al-fe.com
Remote Connectivity Spurs Press Uptime
With over 65 years of experience and over
55,000 Heim/Rousselle machines worldwide, we’ve earned a solid reputation for engineering stamping presses that are dependable, affordable, and built to last. From 15 to 1000 tons, whether
in a heavy-duty Heim, cost effective Rousselle or a full turnkey system, complete with all tooling, transfer mechanisms and coil feeding, let Heim help you handle your next challenge.
See Us At Booth B1102
And remember our other option for your press shop...our rebuilt and remanufactured presses might be the perfect answer for your application and your budget needs.
Made in America, built to last and backed by people who care about customer satisfaction... impressive, isn't it?
REMANUFACTURED PRESSES BEFORE & AFTER
Chicago, Illinois
10
MetalForming/November 2014
Visit www.theheimgroup.com today for the whole story!
Scan here to see our presses in action! LET HEIM HELP! Call 1-800-927-9393
H
