Page 14 - MetalForming May 2015
P. 14
Heavy-Metal Stamper Preps for Feature-Rich Robust Feed Line
After a recent surge in business and the purchase of an additional press, Canadi- an metalforming company Excell Stamping Inc., Kenilworth, Ontario, turned to Colt Automation for a new feed line. Company officials specified the new line for heavy-
gauge blanking. It replaces an existing cra- dle straightener that had served well past its productive life.
other parts of the plant for the firm’s sole overhead crane. Identical to a line Colt designed and installed at Excell in 2014, it features hardened side rollers in hydrauli- cally powered 1-in. outer side plates, with a 3⁄4-in. wear plate inside to help avoid material jamming. A hydraulically powered cushion roll absorbs any shock of the loading coil and helps to control the coil as it rolls into place on the 8-in.-dia. cradle rolls. And, an extendable peeler/threader blade easily peels the leading edge of the top payout coil being driven by the motorized holddown roll, and directs the material onto a pivot deflector table and dekinker.
Excell Stamping had begun to experi- ence difficult coil changeovers that required several operators as long as 30 min. to
complete. The twist to the story came when Excell asked Colt to provide a
cradle straightener unlike most traditional cradles—it wanted to stamp 25,000- lb. coils of material 0.40 in. thick by 24 in. wide from the top of the coil, while employing a nine- roll straightener. And, the width of the machine had to be stretched to accom-
Ultimately, the material enters the 6-in.- in.-dia. feed rolls and nine-roll straightener with 6-in.-dia. straightener rolls. Straight- ening and pinch rolls are of Type 52100 avi- ation-grade alloy shaft rolls, ground and chromed to RC 60/64. All transitions are machined and then cylindrically ground, pol- ished and chromed along with the roll
modate 26-in. material. In the end, Colt designed a self-loading coil-cradle ramp to hold a staged coil—no need to fight with the
A FAMILY OF PERFORMERS SINCE 1946 ...
With over 65 years of experience and over
55,000 Heim/Rousselle machines worldwide, we’ve earned a solid reputation for engineering stamping presses that are dependable, affordable, and built to last. From 15 to 1000 tons, whether
in a heavy-duty Heim, cost effective Rousselle or a full turnkey system, complete with all tooling, transfer mechanisms and coil feeding, let Heim help you handle your next challenge.
And remember our other option for your press shop...our rebuilt and remanufactured presses might be the perfect answer for your application and your budget needs.
Made in America, built to last and backed by people who care about customer satisfaction... impressive, isn't it?
REMANUFACTURED PRESSES BEFORE & AFTER
Chicago, Illinois
12
MetalForming/May 2015
Visit www.theheimgroup.com today for the whole story!
Scan here to see our presses in action! LET HEIM HELP! Call 1-800-927-9393
H
