Page 64 - MetalForming May 2015
P. 64
NEW SERVO FEED LINE & ADVANCED CONTROLS FROM RAPID-AIR!
COMBINING ROCK SOLID
DEPENDABILITY AND PERFORMANCE
WITH THE LATEST CONTROL ADVANCEMENTS.
Today’s press room needs the best of both worlds. The proven Rapid-Air quality you’ve relied on for more than a half century, plus the latest control capabilities to satisfy your specific press room needs.
INTRODUCING OUR NEW, MECHANICALLY SUPERIOR SERVO FEED LINE:
A tough, compact, ridged body design featuring side-pinned, no-weld construction for long service
life and dead on alignment. Built in the USA employing the highest quality materials and craftsmanship to deliver high, accurate production. Reduced product delivery lead times, local application expertise, unmatched parts availability should you ever need it.
MINIS
SE
E
ER
R
RV
V
V
O
O M
M
MO
Available in 2”, 4” and 8” widths, capacity to .040”, speeds up to 700 S.P.M.
100 SERIES MODELS Available in 6”, 12” and 18” widths,
capacity to .105”. Air pilot release, cascade rolls, JOG and SFI compatible. Choose the performance you need.
200 SERIES MODELS Larger roller diameter with high
speed and higher capacity. Available in 8”, 12”, 18” and 24” widths, up to .125” thick capacity.
O
OD
D
E
E
E
L
LS
S
NEW CONTROL CAPABILITIES:
New state-of-the-art feed control. A touchscreen and intuitive programming makes for user-friendly data entry
of up to 99 different job profiles, all stored for future recall. Feed lengths can be displayed or entered in either inches
or millimeters, changeable at will with a touch of the screen. Special programming, such as GAG or other languages,
is available.
Easy press control interface, easy access electronic drive components housed in a robust, free standing console. Retrofits to many earlier Rapid-Air models.
RAPID-AIR 4601 Kishwaukee Street, Rockford, IL 61109 USA (815) 397-2578 • Fax: (815) 398-3887 • www.rapidair.com
