Page 10 - MetalForming October 2015
P. 10
News Fronts
Agreements
Kent Corp., North Royalton, OH, has announced an agree- ment with DieTronic Lubrica- tion Systems of Sant’ Angelo Lodigiano, Italy, to become the exclusive North, South and Central American representa- tive for the company’s line of antirust machinery.
Kent Corp. to Rep. DieTronic Lube Systems
back circuit, which measures line speed and adjusts oil feed. This allows a controlled amount of protective oil to be applied consistently to the pipe or profile.
Liquide oxyfuel and plasma automatic cutting machines.
Facilities
iron-phosphate system to an environmentally friendly zirco- nium-based powdercoating technology.
DieTronic’s product line consists of antirust machinery for the stamping and tube- and-pipe industries, where it currently has more than 200 machines in operation world- wide. Its LCP antirust machine enables inline application of protective oil onto the surface of pipes and profiles. Oil is applied proportionally to mill speed by the encoder feed-
Lantek CAD/CAM Software to be Marketed with
Air Liquide Cutters
Quality Industries (QI) Inc., La Vergne, TN, has invested $3.7 million in a new, state-of- the-art powder-coating system at its main operational metal- working facility just outside of Nashville.
Kent Corp. provides entry equipment, strip end welders, accumulators, high-speed cold saws and tube-mill con- sumables to the tube-mill, rollforming and stamping industries.
Quality Industries Adds High-Tech Powdercoating Line
Specific features of the new system include: an I- beam conveyor system that allows for larger, heavier parts and a faster line speed; a washing system that accom- modates longer and wider parts—equipped with feed- back sensors for chemical monitoring of usage and effi- ciency; a system that report- edly exceeds industry stan- dards by yielding more than 2500 hr. of corrosion resist- ance based on ASTM testing; and an oven system that pre- vents thermal conduction and virtually eliminates radiant heat emitted to shop floor.
Lantek, a developer of CD, CAM MES and ERP software for sheetmetal with its U.S. office located in Mason, OH, has announced a partnership whereby the company’s CAD/CAM software will be marketed worldwide with Air
Custom-designed, QI’s new system includes a Nordson ColorMax II spray booth and upgraded conveyor, with cus- tomized washing and oven systems. Beyond this system, the company already has sig- nificantly advanced its funda- mental chemical technology— converting from an
Additionally, the spray booth changes colors in as lit- tle as 10 min., whereas the
www.steinel.com
All you need for tools
Your partner for punching and bending technology
High precision inch guide units made in Germany . Standard and customer-specific guides
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
cm inch
12345678
8 MetalForming/October 2015
www.steinel.com
Visit us at
FABTECH 2015 . Chicago . USA 09th–12th November 2015 Booth 4120 . South Hall
