Page 12 - MetalForming October 2015
P. 12
News Fronts
previous system required 30 min. Overall, these improve- ments have increased pro- cessing speed by nearly 50 percent, according to compa- ny officials.
from 0.039 to 0.125 in. These systems each consist of a 24- in. servo roll feed with a Servo- Master Touch controller, 24 by 14-ft. threading table, heavy- duty straightener, and a 15,000-lb. and 24-in.-wide- capacity coil reel. The third system consists of the same equipment, but is configured to handle coil stock to 36 in. wide and to 0.125 in. thick. The fourth system is for
Each of the new systems features Coe’s new HD-series straighteners designed for processing advanced high- strength steels. The company also will provide installation, startup and training for each of the lines.
In order to maintain this lead- ing position, we need to pro- vide our staff with the best- possible working conditions and high-quality workplaces, which create a pleasant envi- ronment and space for new ideas.”
The investment is part of a larger $12.5-million company- wide capital program for 2015.
Schuler Breaks Ground for Innovation Tower
The tower is due for a spring 2017 completion.
Four Coil Lines to Lear in Mexico
coil to 48 in. wide and can process coil from 0.039 to 0.118 in. thick. It features a 48-in. servo roll feed with a ServoMaster Touch controller, a 48 by 14-ft. dual threading table, and a 20,000-lb., 48-in.-width-capacity coil reel. This heavy-duty straightener features an alligator-style peeler-dekinker station for hands-free threading of the coil strip.
Press-technology provider Schuler has broken ground on the Schuler Innovation Tower, a 12-story engineering and technology center that will pro- vide space for 750 employ- ees, at its headquarters in Goppingen, Germany.
MC Machinery Opening Mexico Subsidiary
Coe Press Equipment, Ster- ling Heights, MI, announced that it has received orders for four new coil-processing lines from Lear Mexican Seating Corp. for installation at the company’s Saltillo, Mexico, location. All of the systems will feed new Aida presses being installed at the facility.
“This is a commitment to a high-tech business location in Germany,” says CEO Stefan Klebert. “The name Schuler Innovation Tower reflects our determination to always be at the cutting edge of technology.
MC Machinery Systems, Wood Dale, IL, a Mitsubishi company and supplier of its manufacturing machinery, is opening a subsidiary in El Marqués, Querétaro, Mexico. MC Machinery Systems de Mexico will serve the country’s demand for EDM, fabrication, milling and turning machines built by Mitsubishi and brand families that MC Machinery represents.
Two of the lines are designed to process coil stock to 24 in. wide in thicknesses
FLOW FORM SCREWDRIVING SIMPLIFIED!
DEPRAG
With the (D-FFS) Software, anyone can easily set up and modify the parameters of the direct screw assembly of similar or dissimilar metal parts.
Flow Form Screwdriving (D-FFS)
Intuitive, self learning software that automatically adjusts the screwdriving process. On the HMI Panel, the operator simply enters the screw geometry (shaft diameter and length), part information (layer quantity, material type and with or without through hole) and tightening parameters.
Active nosepiece jaws release the screw as soon as it begins penetrating the metal.
Freely programmable torque up to 15Nm and speed up to 8000rpm. Integrated revolver separator optimizes cycle time by storing the next screw inside the unit.
End tooling can be replaced in seconds.
Optional magazine system supplies screws to the D-FFS without a feedhose.
Watch this animation
DEPRAG, Inc
640 Hembry St Lewisville TX 75057
P 972 221 8731 F 972 221 8163
catalog@depragusa.com mailbox@depragusa.com
Assembly is our specialty 800 4 DEPRAG depragusa.com
10 MetalForming/October 2015
