Page 56 - MetalForming October 2015
P. 56
Previews
Coil-Feed Equipment, Setup
Features and Cost Estimator
Coe Press Equipment Booth S4722, S4734
Coe Press Equipment, Sterling Heights, MI, features a
number of new coil-feed products, including its SpaceMaster
Series 4 compact coil line (schematic shown). The line combines
unwinding, straightening and feeding of coil stock into one piece
of equipment capable of processing higher-strength, higher-yield
materials within space-constrained areas. The SpaceMaster
Series 4 fits within 22 ft. of floor space where a conventional
line would require a 40- to 50-ft. footprint. The Series 4 feed-
er-straightener features Coe’s new servo-actuated pilot release
of the upper straightener rolls. This lift mechanism provides more
accurate piloting timing, faster pilot release and higher speed than hydraulic and pneumatic designs. The systems also feature powered pull-off rolls to maintain tension on heavy-gauge and high-strength materials.
yield strength—into the controls, and the recommended straightener roll-depth set- tings are automatically calculated.
The SpaceMaster Series 4 can handle materials from 0.020 to 0.40 in. thick and 12 to 72 in. wide, and coil weights from 10,000 to 60,000 lb. The systems can achieve press- feed speeds of 70 to 80 strokes/min. as compared to 40 to 50 strokes/min. in traditional compact coil lines.
Coe will calculate savings-based upon ton-usage and toll rate—that can be achieved by blanking inhouse with a Coe Value-Added Series cut-to-length (CTL) line. Inhouse CTL lines provide flexibility to run blanks in the sizes needed, according to company officials, reducing inventory, scrap and overall processing costs while improving quality. www.cpec.com
In addition, the company demonstrates its new Work Roll Advisor feature for straight- ener setup, where a Coe coil-processing line feeds an AIDA DSF-M2-4000 servo press. Roll-depth setting, typically accomplished through trial and error, is automatically cal- culated and, depending on the machine configuration, automatically set. The Work Roll Advisor allows users to simply enter their material specifications—thickness, width and
Power / Speed / Value
November 9-12, 2015 Booth #S4770
Servo Solutions
• Transfer
• Progressive • Tandem
JIER North America, www.jier-na.com, Plymouth, MI USA, 734.404.6683
54 MetalForming/October 2015
