Page 57 - MetalForming October 2015
P. 57
Model 450 Oil-less
Transporters
Model 320B
(the Enforcer)
Model 250
Model 850B (the Slugger)
Model 450B (the Brawler)
Specifications
The Vibro Model 450 Air-Operated Transporter can move up to 125 lbs. of material effortlessly (operating at 35 PSI - 0.4 CFM), including linear scrap removal from machine tools and for other conveying processes. The Model 450 has a total capacity of 125 lbs., plus 60 lbs. of tray weight. Multiple trays can also be mounted on a single unit, replacing several conventional belt conveyors. The compact design of the Vibro Transporter allows installation in tight areas.
Vibro Features Include:
I Two Year Warranty I 100% Air Operated
(no mechanical springs)
I Low Air Consumption
I Variable Speed (12-40 ft./min.)
I Available from Stock
I 100% American Made
I A Cover Guard for harsh environments I Includes Air Regulator and Filter
Optional Features Include:
I Quick Clamps for fast tray removal
I Adjustable Bearing Support for trays
I A Motion Sensor that automatically shuts down machinery if the air supply is ever interrupted
Air Pressure Range
Air Consumption (CFM)
Feed Rate (feet/minute) Sound Level (db-A) Maximum Load
Max. Weight of Tray Transporter Weight
Model 450
35 - 80
60 psi - 1.9 35 psi - 0.4 15 - 40
64
125 lbs. 60 lbs. 30 lbs.
P.O. Box 209, Port Royal, PA 17082 Tel: 717.527.2094 Fax: 717.527.2180 Email: info@vibroindustries.com
Web: www.vibroindustries.com
Global Distribution
FOSMO MASKIN A.S.
Oslo, Norway
UPTON & SULLIVAN CO., LTD
Canada
MTI
Monterrey, Mexico
Now, totally enclosed to protect mechanical components from harsh environments
All New
2
A
E
Y
R
R
Y
T
A
N
W
A
R
