Page 76 - MetalForming October 2015
P. 76
Previews
From metalforming to
fabrication – GOIZPER
products provide
reliable performance
GOIZPER’S NEW 6.49 SERIES SAFETY BRAKES,
EXCLUSIVELY DESIGNED FOR SERVO PRESSES USED IN THE METALFORMING INDUSTRY FEATURE:
A drainage system –
which prevents oil leakage damage from a worn piston seal, by collecting and returning it to the oil circuit.
A flexible mounting system – allowing the brake to be assembled between the servo motor and the frame of the machine, at the end of the shaft or even on another shaft.
A safety valve – for quick oil pressure release and system response - stopping the machine in optimum time.
Goizper offers a range of sizes to cover the market requirements of the servo press industry, from small sizes up to more than 100.000Nm brake torque values.
PNEUMATIC AND HYDRAULIC CLUTCH BRAKES FOR MECHANICAL MACHINERY
IMPROVED OPERATION
and Continuous SPM Operation
Brake Torque vs. Competition
FASTER STOP TIME
FLEXIBLE DESIGN
Distributed by:
YOUR PARTNER IN POWER TRANSMISSION
Goizperusa.com
1-800-813-0844
VISIT GOIZPER USA
Torque Technologies BOOTH #S4291
Array of Hydraulic-Press
Sizes and Configurations
Greenerd Press & Machine Co., Inc. Booth S4467
Greenerd Press & Machine Co., Inc., Nashua, NH, highlights its extensive hydraulic-press capabilities, with experts on hand to discuss user applications and press requirements.
Greenerd hydraulic presses are avail-
able in a variety of styles ranging from gap-
frame and straightside to die-spotting
and forging presses, with product capa-
bilities from 3 to 40,000 tons and bed
sizes exceeding 240 in. The company’s
standard hydraulic presses are offered in an array of sizes and configurations, includ- ing numerous solutions for customized fabricating applications. www.greenerd.com
Dual-Head Laser-Blanking System
LaserCoil Technologies LLC Booth S4584
LaserCoil Technologies LLC, Napoleon, OH, highlights its dual-head, coil-fed laser-cut- ting system, which allows a shared balancing of the workload to decrease processing time and improve productivity. The laser-blanking systems are flexible, with the ability
74 MetalForming/October 2015
ing to company officials. These higher throughput rates make laser-cutting of blanks a viable option as compared to mechanical stamping, eliminating the need for dies and achieving greater flexibility and quicker changeover. www.lasercoil.com
Automation of Press-Line Handling Processes
Strothmann Machines & Handling Booth S4552
Strothmann Machines & Handling, with a U.S. presence in Marietta, GA, specializes in the automation of handling processes in and around press lines, especially for auto- motive companies. The most recent contract, the largest in the company’s history, has Volkswagen de México commissioning Strothmann to modernize a press line in the Volk- swagen production plant in Puebla, Mexico.
Volkswagen has opted for electronic parts transfer by means of the established Com- pactTransfer system, which is ideally suited for small installation spaces. The systems partner will adapt the CompactTransfer to unique onsite requirements. Two dynamic lin- ear-technology modules per press gap are mounted on existing press bolsters. Both sides are identical. Suspended between the actuated axes, a crossbar adapts the tooling to grip the blanks. www.strothmann.com
to handle shapes from complex body-side out- ers to simple chevron and scroll cuts.
The dual-head LaserCoil machines can improve produc- tion rates by an aver- age of 85 percent as compared to a single- head system, accord-
