Page 78 - MetalForming October 2015
P. 78
Previews
Servo-Press
Production System
Stamtec Booth S4131
suit their exact needs. Among the many features available are optional magnets with decreasing magnetic force at con- veyor ends, magnetic or nonmagnetic frame construction, constant or vari- able belt speeds, and belts for use in spe- cial environments. The low-profile con- veyors feature rapid and simple belt-tension adjustments an adjustable floor supports.
The Stamtec booth will be flush
with equipment set up as a com-
plete servo-press production sys-
tem. Included will be a 176-ton, two-
point, direct-drive Model iS2-176
press, with variable stroke length,
via pendulum motion, to 8.66 in.,
and offering variable, program-
mable stroke profiles including coin-
ing, drawing, in-die heating and fineblanking modes. Other equipment in the booth: a TLN2-300 servo feed line (material capacity from 5.70 in. wide by 0.125 in. thick to 11.8 in. wide by 0.078 in. thick), and a Forwell quick-die-change system with hydraulic die clamps
The MagSlide is designed to handle dirty and oily parts, jagged abrasive scrap and other punishing materials that often dam- age or jam conventional conveyors. The MagSlide slide-plate conveyor is ideal for transferring ferrous chips, turnings and small parts from stamping presses, lathes or mills, or from slitting or forming opera- tions. The MagSlide is chain-driven and uses permanent high-energy ceramic mag- nets inside the conveyor housing to attract and move ferrous material along the stain- less-steel conveyor faceplate. Optional watertight housings permit installation in virtually any environment.
and lifters, and bolster extensions.
www.stamtec.com
Low-Profile and Other Conveyors
enable manufacturing and processing engineers to essentially design conveyors to
Bunting Magnetics Co. Booth S4135
Bunting Magnetics Co., Newton, KS, showcases the Bunting line of magnetic and non- magnetic low-profile conveyors as well as the MagSlide magnetic chip and parts conveyor. Specifications of the company’s low-profile conveyors include many variables, which
76 MetalForming/October 2015
A
www.buntingmagnetics.com
UNCOIL
THE POWER.
We specialize in:
Strip Connector Alloys, Copper, Brass, Phosphor Bronze, Beryllium Copper, Stainless Steel, and Aluminum Strip
Thin gauges and narrow widths delivered within hours if needed!
Services Available:
Precision Slitting • Tension Leveling Traverse Winding • Pre coating: tin, nickel, or precious • Logistics & Border Crossing
ABC Metals, Inc.
Logansport, IN • Pharr, TX • El Paso, TX 800.238.8470 • fax 547.753.6110 • abcmetals.com
