Page 83 - MetalForming October 2015
P. 83
Tube and Sheet Fabricating Machines
Additive Manufacturing Machine
and 40-Ton Press Brake
Also on display will be a 40-ton all-electric press brake as well as a video wall projecting demonstrations of the company’s laser-cutting systems, other press brake models and shears.
www.e-ci.com
BLM Group USA
Booth N2000 and N2010
Cincinnati Inc.
Booth N9000 and S2799
BLM Group USA, Wixom, MI, features its new LC5 tube and sheet fabricating machine, BC80 end-machining center, and three
Cincinnati Inc., Cincinnati, OH, promotes the company’s latest technologies, including the Big Area Additive Manufacturing (BAAM) machine. BAAM, with a 6 by 12 by 3-ft. work envelope, uses the chassis, drives and control of Cincinnati Inc.’s laser-cutting system as the base, and extrudes hot thermoplastic to build parts, layer by layer.
new all-electric tube bending machines, the Elect102, the E-Turn52 and the Smart.
The compact LC5, equipped with a fiber laser with power to 4.5 kW, is the only high-production machine with automatic loading and unloading that can process both tube and flat sheet in a single machine, according to company officials. It can han- dle bar to 21 ft. in length and tube to 4.75 in. dia. The process- ing of sheetmetal is fully automatic and allows for sheet to 5 by 10 ft. The fiber laser is ideal for cutting both mild steel and high- ly reflective materials such as stainless steel and aluminum.
www.blmgroup.com
The only global tailored solution provider specializing in: Steel
Tailor Welded Blanks, Tailor Welded Coils, Hot Formed Tailor Welded Blanks, & Aluminum Tailor Welded Blanks
Steel Tailor Welded Blanks
Reduce weight, improve performance & costs
Combine all steel grades Part Consolidation
Steel Tailor Welded Coils
Used in coil fed operations Vary gauge, grade, &
coating across coil width
Complete Ablation Combine PHS to PHS
or PQS
Mix alloys & thickness 5000, 6000, & 7000
series alloys
Material Utilization
Part Optimization
TWB Company
P: 734.289.6400 • sales@twbcompany.com • www.twbcompany.com
www.metalformingmagazine.com MetalForming/October 2015 81
