Page 85 - MetalForming October 2015
P. 85
Hydraulic Roller Bars
brakes designed exclusively for servo presses used in the met- alforming industry. Its new 6.49 safety brakes feature a drainage system to prevent oil-leak damage from a worn piston seal, by col- lecting and returning it to the oil circuit; a flexible mounting sys- tem that allows the brake to be assembled between the servo motor and the press frame, at the end of the shaft or even on another shaft; and a safety valve for quick oil-pressure release and sys- tem response. www.goizperusa.com
Standalone Android App for ERP Software
Hilma Div. of Carr Lane Roemheld Mfg. Co. Booth S4418
Hilma Div. of Carr Lane Roemheld Mfg. Co., Fenton, MO, dis- plays hydraulic roller bars from Hilma that are used in pairs or sets
to lift the die and provide a roller surface to easily roll the die in and out during the die-change process. For use in standard 11⁄16-in. or ASA T-slots, the bar’s hydraulically operated support- ing rollers allow simple movement in line with the bar.
Shop Edge Software Inc. Booth S4022
Rollers can be positioned for front-to-back or left-to-right move- ment. Maximum operating pressure is 1740 psi. Available in four sizes, the roller bars are in stock and ready to ship.
Shop Edge Software, Kitchener, Ontario, Canada, pres- ents a significant upgrade to its native Android application, which gives users complete shop-floor control from their existing devices to reduce hardware costs. The app makes full use of an Android device’s capabilities including the camera and alert noti- fications, and provides seamless integration with the Android platform.
Safety Brakes for Servo Presses
Torque Technologies, Inc.—Goizper USA Booth S4291
Goizper, Sarasota, FL, has developed a new series of safety
www.clrh.com
Highlights from the Android app include functionality for pro- duction, quality, inventory management, shipping and receiving, and tooling and equipment. The new features empower managers and shop-floor employees by providing simplified data entry and easy access to decision-making metrics, according to com- pany officials. www.shopedgesoftware.com
PLATE | SHEET | COIL | STRIP | NEAR NET SHAPES
STAINLESS STEEL
17-4 PH 17-7 PH 301
301 1⁄4 301 1⁄2 301 FH
302 309/309S 304H 310/310S 304/304L 316/316L
321/321H 347/347H 410
825 Alloy X
Water Jet Cutting Laser Cutting Precision Sawing
We’re Your Specialist in Specialty Metals!
United Performance Metals is your source for high temperature, high strength, and corrosion resistant alloys. Our comprehensive inventory of sheet, coil, and plate can be processed to your exact specifications.
DUPLEX STAINLESS STEEL 2205
NICKEL ALLOYS
20 A286 601 718
263 400 617 X750 C-276 600 625 800H/HT
COBALT ALLOYS L605 188
FIRSTCUT+® Services
Precision Shearing
Hi-Definition Plasma Cutting
Cut-To-Length/ Leveling
Slitting Edging
Call 888.282.3292 for the Metal You Need and the Solutions You Want! www.upmet.com | sales@upmet.com
MetalForming/October 2015 83
