Page 87 - MetalForming October 2015
        P. 87
        Live Five-Axis Waterjet Cutting
Demonstrations
 Ebner Furnaces, Inc., Wadsworth, OH, has added a new 1900-mm-wide press hardening furnace to supplement 2500-mm- wide HotPhase units in operation worldwide. The narrower roller- hearth furnace retains all of the features of its wider sibling, and offers exceptional temperature uniformity and low maintenance. Heating may be with natural gas, electric resistance or a hybrid design utilizing the advantages of both. The modular length design allows selection of the right-sized furnace for the application. Furnaces may be configured for atmosphere operation, allowing processing of either coated or uncoated steel blanks.
www.ebner.cc
The waterjet manufacturer also shows its new, economical Boss- Cutter three-axis waterjet system, new 55,000-psi, 30-hp iP60- 30 waterjet intensifier pump and X-Stream pressure intensifier pumps.
Jet Edge, Inc. Booth S1974
Jet Edge, Inc., St. Michael, MN, performs live abrasive water- jet cutting demonstrations on its Edge X-5 five-axis waterjet sys- tem with Aquavision Di control and closed-loop filtration system.
 Roller-Hearth Hardening Furnace
Ebner Furnaces, Inc. Booth S4341
T
The Edge X-5 cuts precise taper-free parts from virtually any material, and is capable of cutting sophisticated 3D parts such as impellers and bevels to 50 deg. www.jetedge.com
  Metalworking Fluids for:
Metal Forming – Metal Removal – Tube Bending – Rust Preventives – Specialty Lubricants
KLENEDRAW®
– Automotive Approved Synthetics
– VOC Free – Vanishing Oil Replacement – AHSS Lubricants for the Toughest Parts
        www.toweroil.com • 773-927-6161• support@toweroil.com
MetalForming/October 2015 85
Saf-T-Vanish® TOWERPRO
