Page 10 - MetalForming December 2015
P. 10
Large Hydroforming Presses for Deep Drawing
Beckwood Press Co., St.
Louis, MO, has advanced
its Triform sheet-hydro-
forming product line with
the introduction of new, large
deep-draw BD-series mod-
els. The new models include
updates to the pressure-
containment system that
reportedly result in signifi-
cantly improved cycle times.
Also, each new press comes
equipped with Triform’s stan-
dard, efficient and ergonom-
ic tool-change system that
minimizes changeover times.
A cartridge-style chamber is conveyed through the rear opening of the press, present- ing the blankholder and punch to the operator. An optional T-table allows the operator to stage a secondary cartridge, including the blankholder and punch. The system also allows the press to convert quickly from a deep-draw configuration to a fluid-cell con- figuration, for shallow forming without the need for a movable punch tool.
The new BD designs are configurable, giving metalformers options for either a hor- izontal layout with the hydraulic power unit (HPU) positioned to the side of the forming chamber, or a vertical one, which features a crown-mounted HPU. Where floor space is a concern, the vertical configu- ration is significantly smaller than previous Triform models with an equivalent forming area.
www.triformpress.com
Electrostatic
Lubrication System
YOU CAN GET THE BEST VALUE, PERFORMANCE, DELIVERY AND SERVICE...ALL FROM HEIM!
Our Maxi-Stamper® presses represent the leading edge in design and engineering for applications in the 90 to 1000 ton range.
With Maxi-Stamper® presses on your floor, you also realize these benefits...
HEIM delivers what we promise...a solid machine that performs to your requirements, backed by support that’s second to none.
HEIM can engineer a single-point, two-point, four-point or customized Maxi-Stamper® press to meet your needs...whether you need a single press or a complete turnkey system.
...all made in America with our family pride, standing right behind every machine.
SEE HEIM IN ACTION
LET THE HEIM TEAM HELP 1-800-927-9393 www.theheimgroup.com Chicago, Illinois
Easy on the Budget
Coldwater Machine Co., Coldwater, OH, through an agreement with Avant Garde Technology, Lake Mary, FL, introduces the StaticLube electrostatic lubrication system, for sheetmetal and coil stock. The environmentally friendly setup prom- ises 100-percent efficiency with zero costs
TM
8 MetalForming/December 2015
H
