Page 12 - MetalForming December 2015
P. 12
Materials & Coatings
Tool Coating Improves Stripping, Prolongs Tool Life
Environmentally Friendly
coated materials.
CorroKleen 44 rust remover comes in 5-gal. pails and 55-gal. drums, and can be applied with a brush, airless spray nozzle or manual sprayer. www.ppgtruefinish.com
www.mate.com
Mate Precision Tooling, Anoka, MN, has introduced its SuperMax tool coating, promising to greatly improve CNC punch-press stripping and extend tool life. Providing a hard, wear-
Rust, Mill-Scale Remover
resistant and lubricious coating, the proprietary SuperMax coat- ing acts as a barrier between the punch and sheetmetal. Com- pared to previous coatings, it reportedly provides more hits between sharpenings, which reduces machine downtime. It also reduces galling, slug pulling and corner breakdown.
PPG Industries’ industrial coatings business, Pittsburgh, PA, has introduced Corrokleen 44 rust remover, an application- friendly citric-acid-based gel cleaner that proves effective at removing rust and mill scale, while being safe for users and the environment. Formulated without phos- phates and other strong acids, Corro- Kleen 44 features a shear-thinning gel structure for simple spray application, and a low-shear thixotropy that adheres the product to surfaces.
SuperMax is applied using state-of-the-art nano-layer technology to develop a hard, dense film that greatly increases wear resist- ance and with a lower friction coefficient, by approxi- mately 20 percent com- pared to previous coatings. This means less heat buildup, minimized galling
Use the cleaner on rusted or mill- scaled hot-rolled steel or rusted cold- rolled steel to effectively eradicate metal- lic oxides, heat scale and heattreated stains. Useful for the removal of blush/flash rust from previously blasted surfaces, it also proves ideal for cleaning industrial machin- ery, hot-rolled steel fabrications, heavy-duty construction equipment, valves and other equipment sensitive to blast media.
Mate’s M4PM, M2 and Durasteel punches in round, rectangu- lar, oval and square punch configurations. Its application effectiveness includes 3000- and 5000-series aluminum, galvanized and stainless steels, and prepainted and vinyl-
Post-Weld Heattreatment
Supports Coil Joining of AHSS Grades
Taylor-Winfield Technologies, Youngstown, OH, has developed post- weld heattreatment systems to help weld and process coils of advanced high-strength steel (AHSS). Success- ful installed references include mul- tiple sites around the world, such as the United States, Brazil and Canada.
Kia’s 2016 Car of the Year Candidate Loaded with AHSS
and longer tool life. SuperMax works well on
The AnnWeld post-weld induction- annealing system can be integrated into any manufacturer’s existing or new welding setup. The system, integral to the welding machine, can mount inline or as a stand-alone. The process improves ductility in the welded joint without sacrificing weld strength, to help prevent weld breaks during sub- sequent line processes.
Check out the secret behind the body structure of the all-new Kia Optima, which uses more than 51 percent advanced high-strength steel (AHSS). That repre- sents a 150-percent increase over the previous model. The vehicle is one of 10 finalists for 2016 North American Car of the Year, as voted on by the Automotive Press Association.
AnnWeld systems include accu-
rate and repeatable heat cycles, pre-
cision temperature control using pyrometer feedback, automatic load tuning, and cus- tom manufactured coils sized for use with existing welders.
www.taylor-winfield.com
As noted in a 1-min. YouTube video, manufacturing the new car body employs hot stamping of components in 16 core stress areas—a 350-percent increase over the previous model. Included in the video are crash tests comparing structure per- formance with traditional steel grades, AHSS grades and hot-stamped steels. www.youtube.com/watch?v=Q3Rp_1BeDic
10 MetalForming/December 2015
