Page 14 - MetalForming August 2016
P. 14
Safety Update
Gloves Offer Cut Protection with Optimum Dexterity
and• Effective use of current, machine- safety technology.
The SmartCut BKCR3520 safety glove from Brass Knuckle Safety Products is an ANSI Cut Level 3 glove designed to combine medium-level cut protection with excellent abrasion and slip resistance. The 3520 also delivers a high level of dexterity. Its slip- resistant foam nitrile palm coat provides a secure grip, while the reinforced thumb crotch offers excellent abrasion resistance in the glove’s most critical wear area— between the thumb and forefinger.
Brass Knuckle Safety Products: www.brassknuckleprotection.com
The awards also recognize companies that exhibit collaboration between their engineering and health-and-safety depart- ments, which helps reduce injury rates while improving production efficiency.
YOU CAN GET THE BEST VALUE, PERFORMANCE, DELIVERY AND SERVICE...ALL FROM HEIM!
Rockwell Automation Sponsoring Safety Awards
Manufacturers, machine builders and system integrators proud of their company’s safety achievements can nominate them- selves for the fourth annual Manufacturing Safety Excellence Awards, sponsored by Rockwell Automation Inc. Winners will be selected on the basis of a true commitment to safety across three key pillars of a comprehensive safety program:
• A strong safety culture,
• Well-executed compliance procedures,
To nominate a company, download the entry form from www.rockwellautomation.com,
TM
With Maxi-Stamper® presses on your floor, you also realize these benefits...
HEIM delivers what we promise...a solid machine that performs to your requirements, backed by support that’s second to none.
HEIM can engineer a single-point, two-point, four-point or customized Maxi-Stamper® press to meet your needs...whether you need a single press or a complete turnkey system.
...all made in America with our family pride, standing right behind every machine.
SEE HEIM IN ACTION
LET THE HEIM TEAM HELP 1-800-927-9393 www.theheimgroup.com Chicago, Illinois www.metalformingmagazine.com
Our Maxi-Stamper® presses represent the leading edge in design and engineering for applications in the 90 to 1000 ton range.
12 MetalForming/August 2016
H
