Page 12 - MetalForming August 2016
P. 12
Panel-Bending Machine Promises Simple Setup and Operation
The BCe Smart 2220, a new panel- bending machine from Prima Power North America, Arlington Heights, IL, features a large working table that allows loading and unloading in a single sequence to increase productivity. The machine, which does not require skilled operators, uses a barcode reader and automatic-tool- change system to provide automatic setup.
ing energy consumption and maintenance costs.
Ergonomic and safety considerations are a priority in design of the machine, according to company officials. As a result, the BCe Smart 2220 features the absence of physical barriers for manual loading, warning lights, acoustic signals to syn- chronize loading and unloading, program- mable luminous reference for the simple positioning of the pieces to be machined,
and an interactive display that guides the operator in the working phases to be car- ried out, such as the orientation of work- pieces. Working-table side sections can be lowered to allow closer access for load- ing or unloading medium-sized sheets.
To ease production, the machine includes open numerical control by Prima Electro, the Tulus operator interface and the Master Bend Cam programming sys- tem. The machine also is designed to be integrated with robots for automatic loading and unloading.
The flexible machine is ideal for pro- ducing small volumes, kits of components and individual parts. Other reported plusses include compact layout, low main- tenance and simple installation, with servo-electric actuators significantly reduc-
Maximum bending length of BCe Smart is 2250 mm and the size of the machinable sheet can vary between 180 by 360 mm and 1500 by 2850 mm. Bending force is 32 tons.
Prima Power: www.primapower.com
Fresh Rolls Made Daily
to your exact specification
Stainless Steel
precision rolled, light gauge,
tight tolerance coil and strip
Our strength lies in our ability to provide light gauge, tight tolerance material, made to customers’ exacting specifications, while providing quick lead times and excellent on-time delivery.
Need a small trial order for a new program? Need tighter gauge tolerances? Need custom properties dialed into your needs?
...Roll with Eagle MetalsTM
For technical expertise and problem solving skills on your next project, call our customer service team and staff metallurgists, ready to help, giving smart solutions to your material issues.
Send us your quote TODAY Leesport, PA 1.800.223.7005 sales@eaglemetals.com
El Paso, TX 915.633.1760
10 MetalForming/August 2016
