Page 52 - MetalForming October 2016
P. 52
Previews
Quick-Change Punch-Press Tooling
Mate Precision Tooling Booth C36069
Mate Ultra QCT tooling—simple and intuitive to set up and fully compatible with Mate’s Ultra family of guides and standard canisters—will star at the company’s display at FABTECH. To set up the tooling, an operator flips the latch
nice feature—only one punch driver is needed for rounds or shapes.
Also on display: Mate’s new Salvagnini P0 fully guided perforating tool, designed to accommodate any shape to 0.492-in. dia. Tight stripper clearance prevents lateral punch movement for accurate hole punching.
www.mate.com
Angle Rolls, Section Benders and More
Carell Corp., Eagle Bending Machines Booth C37085
Carell and
Eagle will exhib-
it the new T40
horizontal press
with program-
mable control;
3-in. CNC angle
rolls; 10 by 3⁄8-in.
CNC four-roll plate roll; 4-ft. by 12-gauge hydraulic single pinch roll; 308HV4 5-in. angle roll, Eagle 2-in. CP40H section bender with new DP7 direct radius control; Eagle BA35 CNC section roll; and the new ETM90 3-in. programmable pipe/tube-bending machine.
www.carellcorp.com
to remove a tool and snaps a new insert into place. The punch is keyed at the perimeter of the tool, not the center, providing optimum angularity control. The shoulder of the punch remains securely guided when punching. Another
Punch, Flat Bar Shear, Angle Shear, Cope & Notch, we can do it all with Authority...
Shown with Optional Press Brake
100% Made in the USA
5-StationFabricationCenter...
Featuring two-cylinder/two person operation, allowing the punch and shear end to be operated independently and simultaneously at full capacity and speed.
MM-Series include...
• Punch Press • Flat Bar Shear • Plate Shear • Coper/Notcher• Angle Shear
• Round & Square Shear (Optional)
• Standard models 45 tons to 135 tons
Gap-Bed Hydraulic Punch Press...
The GB series is ideal as a dedicated punch press, but easily accepts a wide range of standardaccessoriesandspecial toolingto allow shearing or forming for special jobs.
Double your production
with the DP series...
Back-to-back hydraulic punch presses with a single power source and separate controls.
Kalamazoo Metal Muncher
Phone: 269-492-0268
Email: info@kalamazoometalmuncher.com Web Site: www.kalamazoometalmuncher.com
50 MetalForming/October 2016
