Page 60 - MetalForming October 2016
P. 60
58
Contact us today for all your precision tooling for stamping, roll forming and metalforming.
800.243.1492
www.AmericanPunchCo.com • info@AmericanPunchCo.com MetalForming/October 2016
Booth C15028
Don’t let the precision die components be the piece in your manufacturing puzzle that prevents you from keeping your lines
up and running.
Booth C24085
Automation Details Ball Lock Buttons
a
Modular Punch-Laser Combination Machine
Trumpf
Booth C35041
The new TruMatic 1000 fiber is the first entry-level punch- laser combination machine from Trumpf with a solid-state laser. The machine, on display at FABTECH with a 3-kW TruDisk laser, is revolutionary in its modular design, offering users the ability to add to it as business grows. The machine’s
Delta Drive moves the electric punching head and the laser along the Y axis while the sheet moves in the other direction. This feature not only increases machine dynamics, produc- tivity and process stability, it also enables a significantly compact footprint and the ability to connect with innovative material-handling options, including the SheetMaster Com- pact, to further increase production.
The machine’s protective housing, a requirement for safe laser processing, is integrated into the system. It automatically moves out of the way when the machine is punching to give operators maximum visibility and accessibility. www.us.trumpf.com
Automatic Leveling System
The Bradbury Group Booth C44023
Bradbury will
present its automated
e-Drive leveling systems to
the FABTECH crowd, showcas-
ing a setup that reads the shape
of the strip and automatically
initiates the lev-
eler to self-
adjust.
This new
system
uses I-
unit moni-
toring and improvement to automatically correct for shape changes throughout an entire coil.
Development of worldclass controls and a unique set of options, including the exclusive e-Drive, make the levelers easy to operate, productive and energy efficient, while main- taining control of tension and flatness repeatability. www.bradburyco.com
B
B
all Lock Retainers • Blade Punches Cut-off Dies • Die Inserts
Die Components Headed Punch Retainers Headed and Ball Lock Punches
C
ustom Details • Roll Form Details
C
Headed and Headless Die Buttons
H
u
Previews
