Page 62 - MetalForming October 2016
P. 62
Previews
Power-Straightener Upgrades and Retrofit Capability
Well-Suited for Processing AHSS
Coe Press Equipment Booth C16020
Coe will showcase its 350-series power straighteners with new design features that enable processing of a wider range
of materials including advanced high-strength steels
(AHSS). The straighteners offer a 30+-percent improve-
ment in strength and rigidity due to
increased roll-journal diameter and
radius, and increased bear-
ing-loadcapacity.Thestraight-
eners also feature enhanced out-
board support, new idler shafts,
improved backup design
and other updates. Impor-
tantly, the straighteners
also increase work-roll
penetration by 30 percent,
helping achieve the mate- rialflatnessrequiredtoproperlyfeedAHSS.
The 350 straighteners handle coil widths from 1.0 to 54 in., thickness from 0.010 to 0.310 in., and coil weight to 30,000 lb. And, the modular design of their straightener heads allows them to be retrofitted to existing coil-processing lines. www.coepress.com
New Trio of Mag Drills
Hougen Mfg. Booth C21021
Hougen will showcase its line of portable magnetic
drills, annular
cutters and
other hole- making prod- ucts. New: three models of magnetic drills along with new addi- tions to the annular-cutter lineup.
Also on dis-
p l a y
w i l l
be a
new cordless hole puncher, and several models of portable punches and vari- ous sheetmetal hole-cutting products. www.hougen.com
United Performance Metals is your source for high temperature, high strength, and corrosion resistant alloys. Our comprehensive inventory of sheet, coil, and plate can be processed to your exact specifications.
We’re Your Specialist in Specialty Metals!
PLATE | SHEET | COIL | STRIP | NEAR NET SHAPES
NICKEL ALLOYS
20 A286 263 400 C-276 600
STAINLESS STEEL
17-4 PH 301 1⁄4 17-7 PH 301 1⁄2 301 301 FH
DUPLEX STAINLESS STEEL
2205
FIRSTCUT+® Services
601 718
617 X750 625 800H/HT
302 309/309S 304H 310/310S 304/304L 316/316L
825 Alloy X
321/321H 347
410
COBALT ALLOYS
L605 188
Precision Shearing
Hi-Definition Plasma Cutting
Cut-To-Length/Leveling Slitting
Edging
Water Jet Cutting Laser Cutting Precision Sawing
Call 888.282.3292 for the Metal You Need and the Solutions You Want! www.upmet.com | sales@upmet.com
Booth C15095
60
MetalForming/October 2016
