Page 66 - MetalForming October 2016
P. 66
Previews
Automobile Press Line with Automation System
Strothmann Machines & Handling GmbH Booth C14108
The FeederPlus linear robot system from Strothmann, equipped with addi- tional rotating axes that can orient
blanks during transfer, promises to outperform conventional six-axis robots in press-automation applica- tions, in terms of speed and flexibility. The concept, proven in many tandem press lines, can perform rotary motions in the B axis—orienting the rotating arm. Due to a laterally offset design,
the diagonal speed component can be eliminated. The unit suits operation in press gaps measuring at least 6500 mm and as large as 11,000 mm; maximum load is 125 kg. Repeatability, ±0.25 mm.
Also on display: the CompactTrans- fer system that makes orientation sta- tions between presses unnecessary. The system picks up the parts, orients them and places them in the following press all by itself. www.strothmann-us.com
Logopress3 Now Animates
Transfer Dies
Accurate Die Design Software Inc. Booth C15031
After having
animated pro-
gressive dies for
many years with-
in its die-design
software, Logo-
press3 has added
transfer-die ani-
mation as well.
In addition, the
software now
allows for realis-
tic animation
with various
press types so
that users can
accurately simu-
late motion
curves for servo
presses and link-
motion presses.
Varying progressions through a transfer die can be simulated along with stock lift at stations independent of the other stations. Rotation of the part also can be simulated, as can every other func- tion including cams.
In addition to the visual animation, interference also can be checked through the entire tool as the parts of the die are moving exactly as they would in the press. This includes the strip, or in the case of a transfer die the individual parts, as they are lifting, advancing and even rotating in the press.
www.diedesignsoftware.com
THE BIG NAMES TRUST US. THE SMALL ONES TOO.
Cimatron is now part of 3D Systems THINGS ARE GETTING BIGGER AND BETTER
As one of the early pioneers developing CAD/CAM software for manufacturing, Cimatron will continue its 33 year legacy going forward as part of 3D Systems.
Look forward to new opportunities for MANUFACTURING THE FUTURE!
For more information go to:
www.3dsystems.com www.cimatrontech.com
Booth C10104
Our clients know they can always expect custom solutions from us, whether they are big or small. A highly qualified team is always ready to provide effective answers to any need because we control the entire production process. Sensors for force, position, pressure and temperature measurement; indicators, power and temperature controllers; automation platforms and industrial inverters: whatever your need, you can trust us.
GEFRAN INC
8 Lowell Avenue Winchester, MA 01890 - Toll free 1-888-888-4474 info.us@gefran.com - www.gefran.com
Booth C14053
64
MetalForming/October 2016
