Page 64 - MetalForming October 2016
P. 64
Previews
What’s Next?
Portable Magnetic Drill with
Automatic Feed and Reverse
CS Unitec Booth N2311
CS Unitec has introduced a new model to its MAB line of portable magnetic drills, the AutoMAB 350, which features an automatic feed mechanism with auto- matic reverse and shutoff. Ideal for steel fabricators, contractors and plant-main- tenance professionals, the AutoMAB 350 drills holes as large as 1.5-in. dia. with annular cutters in structural steel and other materials. Max. drilling depth: 23⁄8 in. with a pilot pin, 43⁄8 in. without a pilot pin.
An integrated automatic cooling/lubri-
cation system maximizes cutter life by
reducing friction and wear. Designed for
continuous use, the drill operates at 450 rpm. And, to ensure safe operation, the CS Unitec Safemag system determines whether the magnet has sufficient adhesive force on the material and alerts the user with LED indicators—green for go, red for stop. An electronic safety shutoff sensor automatically shuts down the drill motor if the magnet loses contact.
www.csunitec.com
Part- and Die-Costing Software
Forming Technologies Inc. Booth C17096
FTI recently released FormingSuite 2017, which features two new solutions, ProcessPlanner (part and die costing) and FastIncremental (die prove-out). ProcessPlanner provides users with a quick and accurate method for blank develop- ment, coil nesting, trims and piercings, and recognizes part features to determine the cor- rect operations within the tool- ing. This allows the software to accurately quote and pro- vide full reports to customers, with tonnage, operations in each station and the press available to manufacture each project. This solution accurate- ly targets customer needs by meeting target costs on all
RFQs, and all within a 5-min. quoting process.
The FastIncremental analysis solution—fully associative and regenerative to
reduce downstream design changes—provides a detailed virtual die tryout for users with limited knowledge in the field. Users will experience significant savings in blank-development time.
www.forming.com
RMC150
Up to 8-Axis
1 or 2-Axis
Booth C18108
RMC200 Up to 32-Axis
Introducing the new RMC200
Delta’s most capable electro- hydraulic motion controller. The RMC200 controls up to 32 axes, and our familiar RMCTools software makes it easy to synchronize every one of them — from simple single-loop position control to complex dual-loop control of position-pressure/force. Make ‘What’s Next’ happen for you. Just call 1-360-254-8688 or visit deltamotion.com
RMC200 module with door open to the right displaying labels. The terminal blocks feature push-in wiring and latch ejectors to speed wiring and simplify maintenance.
62
MetalForming/October 2016
RMC75
