Page 15 - MetalForming May 2017
P. 15
Crowning Setup
The days of controlling deflection using stacked cardboard, gum wrappers or any other type of makeshift shim are over, thanks to the introduction, by Wilson Tool International, White Bear Lake, MN, of the Express Crowning system. Designed to help control deflection (or the “canoe effect”) in press-brake applications exceed- ing 4 ft. in length, the system gives fabri-
application.
Coldwater Machine: www.coldwatermachine.com
State-of-the Art
Press-Brake
Use the machines as stand-alone cells or integrate them into existing manufac- turing processes to work with robots, con- veyors and inspection stations. They accom- modate a variety of laser markers, and custom fixtures can be engineered for any part-marking
QUICK DIE CHANGE
Automatic or Manual
Hilma has been safely clamping dies for more than 50 years. We work with you to develop an automatic or manual die change system to suit your needs.
We provide the products and support to keep you competitive in today’s manufacturing environment.
New Automatic Flexline Traveling Clamp
Fenton, MO 63026 800-827-2526
Manual Clamping Nut
www.Hilma-usa.com
See Quick Die Change Products at:
cators the flexibility to fine-tune the deflection-compensating curve of the unit to overcome
the nuances
built into the press
brake. Press-brake
operators can
crown the lower
beam with manual or electric options and secure dies with manual or hydraulic power.
Mounting is available for all types of press brakes, and the setup is compatible with WT and American-style tooling. Adjust the hydraulic clamping system with a remote control or CNC direct to the machine control. Macro crown up to 2 to 3 mm, depending on length.
Wilson Tool Intl.: www.wilsontool.com
Laser-Marking
Systems Deliver
Speed, Quality
Multi-position, servo-rotary-index laser- marking machines from Coldwater Machine Co. allow operators to load/unload com- pleted parts while other parts are being marked. A single-swipe cycle-start function, with integrated safety light curtains during indexing, ensures operator protection. And, all laser components and controls are self- contained in a durable Class 1 enclosure.
MetalForming/May 2017 13
