Page 17 - MetalForming May 2017
        P. 17
                       To learn more about the program requirements and to gain access to MSCI’s safety resources, visit www.msci.org/safe- typrogram.
including earplugs available in disposable foam and reusable silicone, in corded and uncorded options. Each pair comes
Draw-Bar Cover Protects Milling- Machine Operators
Safety Update
 as they strive for a zero-incident environ- ment, according to MSCI officials.
individually packaged, and is dispensed from an easily accessible, retail-ready box. Also available: high-visibility lime ear- muffs, from economy to cap-mounted and premium versions, that are ANSI S3.19- 1974-rated. Noise-reduction ratings range from 22 dB to 27 dB.
Global Glove & Safety Manufacturing Inc.: www.bullheadsafety.com
     Vibro Transporters
Remove Stamped Components and Scrap Efficiently and Cost Effectively
Model 850
Model 450
Model 320
Model 250
Global Distribution
For over 30 years, the stamping industry has given the stamp of approval to the Vibro Transporter for their scrap removal needs.
At 0.4 cfm, there is no substitute for the efficiency of the Vibro Transporter. Due to their durable rugged design, many of the Vibro Transporters first sold in 1985 are still in operation today.
All four Vibro models are 100% air operated and 100% made in the USA. Each
Vibro unit is backed by a standard two- year, renewable warranty.
Register online or call us to receive your product line kit, application video, engineering support, or to locate a
sales representative nearest you.
    MTI MONTERREY, MEXICO
CSP EQUIPMENT INC., Ontario, Canada
VEUGEN INTEGRATED TECHNOLOGIES LTD.
Ontario,Canada
FOSMO & DELI A.S.
Oslo, Norway
717.527.2094
                            www.vibroindustries.com
Milling machines can endanger oper- ators should they come into contact with the machines’ high-speed rotating draw bars. Protect operators from this inherent
 danger by implementing this new draw- bar cover from Rockford Systems, designed to protect workers from rotating shafts 7 ft. or less from the floor or working platform.
The cover guards the turning draw bar with a non-rotating, smooth, welded-steel enclosure, firmly secured to the mill with a ring magnet and a 24-in. zinc-plated steel anchor chain. Simple to install, the draw-bar cover prevents clothing, hair or hands from being grabbed by the moving shaft. The welded-steel enclosure has a 4.95-in.-dia. base and 7.125-in. extrusion, and weighs 4 lb.
Rockford Systems LLC: www.rockfordsystems.com
Hearing-Protection Solutions
The Bullhead Safety brand of Global Glove & Safety Manufacturing has intro- duced a new lineup of hearing protection,
ww.metalformingmagazine.com
MetalForming/May 2017 15
2
A
E
Y
R
R
Y
T
A
N
W
A
R
