Page 14 - MetalForming July 2017
P. 14
New Low-Velocity, Low-Volume Lube-Spray System
LSP Industries, Inc. has intro-
duced the MinaMizer spray unit,
developed to enhance its LVLP
(low-volume, low-pressure) spray
technology to dispense fluids in
a consistent, continuous and con-
trolled manner. MinaMizer systems
reduce costs, say company offi-
cials, by reducing the volume of
the fluids used, directing them
into the area needed, and minimizing cleanup of the stamped parts and the press. All MinaMizer systems incorporate precision valves and regulators to ensure consistency and independent volume control to each nozzle. Standard systems are available to manage two to six nozzles.
LSP Industries: www.lspind.com
Shield Extends Gas-Spring Life
has developed Skudos—shields that protect the sealing and guiding components of the cylinder.
Die lubricants, metal shavings and other contaminants wreak havoc on gas springs and can significantly reduce cylinder life. Help now is available, as Special Springs
The Skudo protective cap extends gas- spring life in severe working conditions
12 MetalForming/July 2017
