Page 67 - MetalForming October 2017
P. 67
Chain Clamp for Round or Cylindrical Pieces
equipped with a rotary index to handle tube and pipe cutting; the LC 2515 C1 AJ turret-press and laser-cutting combination machine, equipped with a compact, automated material-handling tower; and the HG 1003 ARs robotic bending system, combining a press brake with a six-axis robot, automatic gripper changer and automatic tool changer. www.amada.com/america
Laser-Cutting System Features
New Control and Drive System
Lenzkes Clamping Tools, Inc. Booth A5108
Lenzkes will feature its chain clamp for holding round or cylindrical workpieces such as valve bodies, flanges, pump housings and pistons. It’s well-suited for repetitive work because the chain does not have to be dis- mounted, and the chain links do not have to be taken out when clamping different-sized parts. www.lenzkesusa.com
Mazak Optonics Corp. Booth A4001
Mazak will show its Optiplex 4020 Fiber III 8-kW laser-cutting system with the PreviewG Control (with 19-in. LCD touchscreen) for high-response and
high-speed
Automation Shines Here
machine
motion, and a
high-perfor-
mance, digital-
drive package.
The system is
designed to integrate intel-
ligent setup and monitoring functions, and is engineered for use with the company’s material-handling systems.
Amada America, Inc. Booth A1802
Amada will display several pieces of metal-fabricating equipment, all equipped with some sort of automation equipment. Examples: the HG 1003 ATC, a servo-hydraulic press brake with automatic tool changer; the Ensis 3015 RI fiber-laser cutting machine,
www.mazakoptonics.com
Protect Your Workforce Eliminate Pictograms / Hazards
Using Green Fluid Technology
Booth A5435
info@TowerMWF.com 773-927-6161 www.TowerMWF.com
MetalForming/October 2017 65
